cgal-discuss - [cgal-discuss] Delaunay complex
  • To: cgal-discuss <>
  • Subject: [cgal-discuss] Delaunay complex
  • Date: Tue, 19 Mar 2013 09:07:24 +0100
Hello!
I'd like to construct a Delaunay complex for a point set that contains several degenerate cases, i. e., >4 cospherical points. The doc says that theĀ  Delaunay_triangulation_3 code solves the local disambiguity by using a perturbation scheme.
If the tetrahedra that were constructed using this scheme would be marked, I could merge them in a preprocessing step to get a Delaunay complex consisting of convex polyhedra.
Where in the code is the perturbation scheme used to select a possible tetrahedrization? I did not find this.
Best regards,
Philipp
