cgal-discuss - Re: [cgal-discuss] Re: Determining if a point is inside a polyhedron
  • To:
  • Subject: Re: [cgal-discuss] Re: Determining if a point is inside a polyhedron
  • Date: Tue, 26 Mar 2013 18:34:06 +0100
OK let's close this thread.
Here is a minimal and efficient example showing how you can test
if a point is inside a polyhedron.
However it is not yet in CGAL and required a file to be patched.
If you compile the example in the directory provided, it should works
without any problem.
Sebastien.
On 03/26/2013 08:54 AM, ChaoM wrote:
Hello Oleg:
I read your code that "Determining if a point is inside a
polyhedron?" I have the same problem! And I wanna to know "How to
construct a Polyhedron? and when I convert a common Polyhedron to a
Nef_Polyhedon, there is a error!! Finally, I exactly agree with you ,
because My goal is take two Polyhedrons (such as Cone,Clinder,Sphere,Cube
and so on!) intersections! I want to know how do you finish your goal?
Perhaps you can give me some more detail codes!
thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determining-if-a-point-is-inside-a-polyhedron-tp4523460p4657029.html
Attachment: point_inside_polygon.tgz
Description: application/compressed-tar
