cgal-discuss - [cgal-discuss] Re: Determining if a point is inside a polyhedron
  • To:
  • Subject: [cgal-discuss] Re: Determining if a point is inside a polyhedron
  • Date: Wed, 27 Mar 2013 00:53:13 -0700 (PDT)
Hello Sebastien:
I meet a newly problem when I use the codes you give me ! I Make a
simple polyhedron,and I compile the code like this
Point p(1.0, 0.0, 0.0);
Point q(0.0, 1.0, 0.0);
Point r(0.0, 0.0, 1.0);
Point s(0.0, 0.0, 0.0);
Polyhedron polyhedron;
polyhedron.make_tetrahedron(p, q, r, s);
Point query(2,2,2);
CGAL::Point_inside_polyhedron_3<Polyhedron,K>
inside_with_ray(polyhedron);
bool ray_res;
ray_res = inside_with_ray(query);
and there is a error that" \point_inside_polyhedron_3.h(306): error C2383:
“_Other1”......"
I think the problem is into the "Point_inside_polyhedron_3.h"
---->"std::pair<boost::logic::tribool,std::size_t>
status(boost::logic::indeterminate,0);'
I don't know how to solve it ! And I guess it may cause not use the
"internal::r3t3_do_intersect_endpoint_position_visitor visitor;"???
Can you explain it to me? Thank you very much !
Sebastien Loriot (GeometryFactory) wrote
> OK let's close this thread.
> Here is a minimal and efficient example showing how you can test
> if a point is inside a polyhedron.
> However it is not yet in CGAL and required a file to be patched.
> If you compile the example in the directory provided, it should works
> without any problem.
> Sebastien.
> On 03/26/2013 08:54 AM, ChaoM wrote:
>> Hello Oleg:
>> I read your code that "Determining if a point is inside a
>> polyhedron?" I have the same problem! And I wanna to know "How to
>> construct a Polyhedron? and when I convert a common Polyhedron to a
>> Nef_Polyhedon, there is a error!! Finally, I exactly agree with you ,
>> because My goal is take two Polyhedrons (such as Cone,Clinder,Sphere,Cube
>> and so on!) intersections! I want to know how do you finish your goal?
>> Perhaps you can give me some more detail codes!
>> thank you!
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Determining-if-a-point-is-inside-a-polyhedron-tp4523460p4657029.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> point_inside_polygon.tgz (9K)
> &lt;http://cgal-discuss.949826.n4.nabble.com/attachment/4657034/0/point_inside_polygon.tgz&gt;
http://cgal-discuss.949826.n4.nabble.com/Determining-if-a-point-is-inside-a-polyhedron-tp4523460p4657045.html
