- To:
- Subject: [cgal-discuss] Re: Determining if a point is inside a polyhedron
- Date: Tue, 26 Mar 2013 00:54:38 -0700 (PDT)
Hello Oleg:
I read your code that "Determining if a point is inside a
polyhedron?" I have the same problem! And I wanna to know "How to
construct a Polyhedron? and when I convert a common Polyhedron to a
Nef_Polyhedon, there is a error!! Finally, I exactly agree with you ,
because My goal is take two Polyhedrons (such as Cone,Clinder,Sphere,Cube
and so on!) intersections! I want to know how do you finish your goal?
Perhaps you can give me some more detail codes!
thank you!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Determining-if-a-point-is-inside-a-polyhedron-tp4523460p4657029.html
- [cgal-discuss] Re: Determining if a point is inside a polyhedron, ChaoM, 03/26/2013
- Re: [cgal-discuss] Re: Determining if a point is inside a polyhedron, Sebastien Loriot (GeometryFactory), 03/26/2013
- [cgal-discuss] Re: Determining if a point is inside a polyhedron, ChaoM, 03/27/2013
- Re: [cgal-discuss] Re: Determining if a point is inside a polyhedron, Sebastien Loriot (GeometryFactory), 03/27/2013
- [cgal-discuss] Re: Determining if a point is inside a polyhedron, ChaoM, 03/28/2013
