cgal-discuss - [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?
  • To:
  • Subject: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?
  • Date: Tue, 26 Mar 2013 11:45:35 -0700 (PDT)
>BTW, what are you trying to do, a model running in the browser?
Precisely - I guess you've seen my myriad other posts on here :)
I have it working in a single worker thread, but I'd like to delegate CSG
operations on Nef_polyhedron_3 objects to further worker threads. Trouble is
of course worker threads don't share memory - I can only pass a message.
So that message is a list of polys, plus an operation, and the message back
is a single resulting poly of that operation.
I asked the question here:
https://groups.google.com/forum/?fromgroups=#!topic/emscripten-discuss/JeLvBMn9X60
And the lead guy there suggested the possilbilty of a 'bump' allocator.
After further reading I understand this to mean, for instance, setting a
custom frame allocator, creating the instances of the polys one requires
with that allocator, and then saying bytes[] = allocatorInstance.getBytes[].
Then on the other side somehow being able to offset the pointers internal to
the Nef_polyhedron_3 object?
I *sounds* like this might work, but I'm just not sure on the details at the
moment.
Mracos
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/What-s-the-fastest-way-to-serialise-Nef-3-poly-tp4657024p4657038.html
