- To:
- Subject: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?
- Date: Tue, 26 Mar 2013 11:58:49 -0700 (PDT)
I see internal to the Nef_polyhedron_3 structure it's just STL containers,
which can take a custom allocator. I'm just not sure how that works on the
other side. Do you basically copy the chunk of memory, copy it over to
whereever you want it, and say the first item in that is a pointer to a nef
poly? I'm just not sure how to deal with the offsets for the pointers
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/What-s-the-fastest-way-to-serialise-Nef-3-poly-tp4657024p4657040.html
- [cgal-discuss] What's the fastest way to serialise Nef 3 poly?, marcosscriven, 03/25/2013
- [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?, marcosscriven, 03/26/2013
- Re: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?, Sebastien Loriot (GeometryFactory), 03/26/2013
- [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?, marcosscriven, 03/28/2013
- Re: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?, Daniel Pfenniger, 03/28/2013
