cgal-discuss - Re: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?
  • To: <>
  • Subject: Re: [cgal-discuss] Re: What's the fastest way to serialise Nef 3 poly?
  • Date: Thu, 28 Mar 2013 16:46:20 +0000
Le 26.03.13 18:44 marcosscriven a écrit :
Hi Sebastien
Thanks for the response - just wondering if you would confirm my suspicion
the serialisation (particularly deserialisation) is slow due to the string
intermediary, and thus it would likely be worth me doing this manually?
Also, can you confirm that basically what I need to do is:
1) copy vertices, halfedges, facets, volumes, shalfedges, shalfloops,
and sfaces like this:
for each myNef3poly.vertices_begin() -> copy to my protobuf message
(for each of the above)
2) On the other side:
Nef_polyhedron_3 myReconstructedPoly
myReconstructedPoly.sncp.put_vertex_node( protomsg.getVertexNode)
(for each)
Marcos
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/What-s-the-fastest-way-to-serialise-Nef-3-poly-tp4657024p4657035.html
