- To:
- Subject: Re: [cgal-discuss] Re: Divide by Zero in AABB tree
- Date: Wed, 27 Mar 2013 07:37:00 +0100
Could you provide the kernel you are using? the debug stack?
Once I have the debug stack I'll ask you to provide the two geometric
objects involved in the failure.
Sebastien.
On 03/27/2013 07:22 AM, schrodingersnewcat wrote:
I have been unable to make a simple program that exhibits the error. I
encounter it consistently in the larger program I am working on. So the
answer would be it is inside a more complicated piece of code.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Divide-by-Zero-in-AABB-tree-tp4657026p4657043.html
- [cgal-discuss] Divide by Zero in AABB tree, schrodingersnewcat, 03/26/2013
- Re: [cgal-discuss] Divide by Zero in AABB tree, Sebastien Loriot (GeometryFactory), 03/26/2013
- [cgal-discuss] Re: Divide by Zero in AABB tree, schrodingersnewcat, 03/26/2013
- Re: [cgal-discuss] Re: Divide by Zero in AABB tree, Sebastien Loriot (GeometryFactory), 03/27/2013
- [cgal-discuss] Re: Divide by Zero in AABB tree, schrodingersnewcat, 03/27/2013
