- To:
- Subject: Re: [cgal-discuss] Refine edges assertion error
- Date: Fri, 29 Mar 2013 16:14:09 +0100
Le vendredi 29 mars 2013 05:09:51
a écrit :
> Hi,
> I have a 2D Constrained Triangulation (CT), and I define a bigger
> neighborhood around this CT and I intend to mesh (CDT) this full domain
> excluding the original sub-domain of CT. For example consider I have a
> circle of a smaller radius as CT, and I define a bigger neighborhood by a
> circle of larger radius centered on the CT's center. And I need to mesh
> this without changing the faces inside original CT (smaller circle).
Can you show us a picture of what you as input of the 2D mesher? That would
help. I have not managed to understand your explanation (though it seems
complete).
> I looked at the previous similar queries and one that is very similar is -
> http://cgal-discuss.949826.n4.nabble.com/Precondition-Violation-in-Mesh-
Refinement-2-Package-td1585855.html
> I was thinking since its quite some time, so the version 4.0.2 should
> already
> have some patch.
I confirm that the patch was shipped in CGAL-3.6.1 and CGAL-3.7, and later
versions.
Laurent Rineau, PhD
- [cgal-discuss] Refine edges assertion error, ratneshkumar21, 03/29/2013
- Re: [cgal-discuss] Refine edges assertion error, Laurent Rineau (CGAL/GeometryFactory), 03/29/2013
