- To:
- Subject: [cgal-discuss] building error on Mac 10.7
- Date: Fri, 29 Mar 2013 11:05:52 -0500
Hi all,
I tried two ways to install cgal on Mac 10.7, but both fail. Any help is appreciated.
Shiyuan
Generating Alpha_shapes_2.moc
cd /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2 && /opt/local/bin/moc -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2/./include -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2/../../include -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/include -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/include -I/opt/local/include -I/opt/local/include -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2 -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/include -I/opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/include -I/opt/local/include -I/opt/local/include -F/System/Library/Frameworks -I/opt/local/include -I/opt/local/include/QtOpenGL -I/opt/local/include/QtScript -I/opt/local/include/QtGui -I/opt/local/include/QtXml -I/opt/local/include/QtCore -DCGAL_USE_MPFR -DCGAL_USE_GMP -DQT_OPENGL_LIB -DQT_SCRIPT_LIB -DQT_GUI_LIB -DQT_XML_LIB -DQT_CORE_LIB -o /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2/Alpha_shapes_2.moc /opt/local/var/macports/build/_opt_local_var_macports_sources_rsync.macports.org_release_tarballs_ports_gis_cgal/cgal/work/CGAL-4.1/demo/Alpha_shapes_2/Alpha_shapes_2.cpp
opt/local/include/boost/type_traits/detail/has_binary_operator.hp:50: Parse error at "BOOST_JOIN"
2. I also try to build cgal from source. It seems to be able to build the library, but when I try to build the examples, I got the following error:
clang: warning: argument unused during compilation: '-frounding-math'
In file included from /Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/mesh_implicit_sphere.cpp:3:
In file included from /Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/../../include/CGAL/Mesh_triangulation_3.h:27:
In file included from /Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/../../include/CGAL/Regular_triangulation_3.h:30:
In file included from /Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/../../include/CGAL/Triangulation_3.h:37:
In file included from /Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/../../include/CGAL/Triangulation_data_structure_3.h:45:
/Users/sgu/softwares/CGAL-4.1/examples/Mesh_3/../../include/CGAL/Triangulation_ds_cell_base_3.h:51:7: error: array initializer must be
an initializer list
: V((Vertex_handle[4]) {v0, v1, v2, v3} ) {}
- [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Laurent Rineau (CGAL/GeometryFactory), 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Marius Kintel, 03/29/2013
