- To:
- Subject: Re: [cgal-discuss] building error on Mac 10.7
- Date: Fri, 29 Mar 2013 17:19:56 +0100
Le vendredi 29 mars 2013 11:05:52 Shiyuan a écrit :
> Hi all,
> I tried two ways to install cgal on Mac 10.7, but both fail. Any help is
> appreciated.
Which version of CGAL.
> 1. `sudo port install cgal` gives the follow errors. It looks like that
> cgal doesn't work with boost
> @1.53.0_1+no_single+no_static+openmpi+python27which is installed in my mac.
> opt/local/include/boost/type_traits/detail/has_binary_operator.hp:50: Parse
> error at "BOOST_JOIN"
The macport distribution seems buggy. You should report to them.
> 2. I also try to build cgal from source. It seems to be able to build the
> library, but when I try to build the examples, I got the following error:
> clang: warning: argument unused during compilation: '-frounding-math'
The CGAL project does not support the Apple "clang" before MacOS X 11.4. On
10.7, you need to use a real GNU gcc (not the one packaged by Apple). Maybe
you can use macport to install a regular gcc version.
Recently, homebrew seems more reliable than macport or fink:
http://mxcl.github.com/homebrew/
Laurent Rineau, PhD
- [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Laurent Rineau (CGAL/GeometryFactory), 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Marius Kintel, 03/29/2013
