- To:
- Subject: Re: [cgal-discuss] building error on Mac 10.7
- Date: Fri, 29 Mar 2013 13:20:32 -0500
On Fri, Mar 29, 2013 at 11:19 AM, Laurent Rineau (CGAL/GeometryFactory) <> wrote:
Le vendredi 29 mars 2013 11:05:52 Shiyuan a écrit :
> Hi all,Which version of CGAL.
> I tried two ways to install cgal on Mac 10.7, but both fail. Any help is
> appreciated.
CGAL 4.1
> opt/local/include/boost/type_traits/detail/has_binary_operator.hp:50: ParseThe macport distribution seems buggy. You should report to them.
> error at "BOOST_JOIN"
The CGAL project does not support the Apple "clang" before MacOS X 11.4. On
> 2. I also try to build cgal from source. It seems to be able to build the
> library, but when I try to build the examples, I got the following error:
> clang: warning: argument unused during compilation: '-frounding-math'
10.7, you need to use a real GNU gcc (not the one packaged by Apple). Maybe
you can use macport to install a regular gcc version.
Changing to gcc compiler solves the problem.
- [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Laurent Rineau (CGAL/GeometryFactory), 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Shiyuan, 03/29/2013
- Re: [cgal-discuss] building error on Mac 10.7, Marius Kintel, 03/29/2013
