- To:
- Subject: [cgal-discuss] Re: Bounded Power Diagram
- Date: Fri, 19 Apr 2013 08:54:29 -0700 (PDT)
Thanks for your reply. I have looked at your good project page but can't find the code on the link you posted.
On Fri, Apr 19, 2013 at 3:26 PM, Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]> wrote:
You can try this package which simulate a halfedge data structure to
represent the diagram:
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Voronoi_diagram_2/Chapter_main.html
If you need the diagram to be explicitely built, I have experimental
code that creates a hds and crop a Voronoi diagram to a rectangle [1].
It should work for a power diagram too.
Look at main.cpp in test directory.
Sebastien
[1] http://code.google.com/p/cgal-voronoi-cropping/
On 04/19/2013 09:13 AM, liudaisuda wrote:> Sent from the cgal-discuss mailing list archive at Nabble.com.
> Hey, guys. I am new to CGAL and didn't find any documentation to my question
> below. Thanks in advance for you kind help.
> I am trying to generate a bounded power diagram which could simply be done
> by clipping the Power diagram with the boundary. However, this is not what I
> am seeking. I need to compute for each power diagram cell within the
> boundary the centroid. I could store each clipped power diagram cell in a
> convex polygon structure, and then compute its centroid, but with this
> approach I will have to build the power diagram from scratch, and thus make
> no use of the nice features provided by CGAL. My question is, if is there
> any way I can use structures such as constrained Delaunay Triangulation to
> tackle this problem?
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Bounded-Power-Diagram-tp4657223.html
If you reply to this email, your message will be added to the discussion below:http://cgal-discuss.949826.n4.nabble.com/Bounded-Power-Diagram-tp4657223p4657224.html
View this message in context: Re: Bounded Power Diagram
- [cgal-discuss] Bounded Power Diagram, liudaisuda, 04/19/2013
- Re: [cgal-discuss] Bounded Power Diagram, Sebastien Loriot (GeometryFactory), 04/19/2013
- [cgal-discuss] Re: Bounded Power Diagram, liudaisuda, 04/19/2013
- Re: [cgal-discuss] Re: Bounded Power Diagram, Sebastien Loriot (GeometryFactory), 04/29/2013
- Re: [cgal-discuss] Bounded Power Diagram, Olivier Devillers, 04/19/2013
