- To:
- Subject: Re: [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face.
- Date: Fri, 3 May 2013 23:57:40 +0300
On Fri, May 03, 2013 at 11:48:19AM -0700, Pablo Miranda Carranza wrote:
> After some work I have found a better example of the bug I am chasing in
> getting the circumcenters of the segment delaunay (I attach another sample
> program):
> main.cpp <http://cgal-discuss.949826.n4.nabble.com/file/n4657350/main.cpp>
> I have tried a number of different kernels and number types, all of them
> seem to fail (see sample code). In the output text result of running the
> included program one can see that the centre for "circle 14" is: (
> 1.61455e+17, 11.9295 ).
> I attach snapshots of the program I am using to draw the results, obviously
> the program is just to large to include here, but the data is the same. It
> only draws the interior part of the segment voronoi (the medial axis), but
> the error is clearly visible in the largely off position of one of the
> circumcenters.
> <http://cgal-discuss.949826.n4.nabble.com/file/n4657350/Screen_Shot_2013-05-03_at_8.22.26_PM.jpg>
> Do you have any suggestions that may work (any kernels, traits, number
> types...)?
> Thank you for your time!
I am not an expert in number types, but CORE seems to work fine
for the exact number type, instead of CGAL::Quotient<CGAL::MP_Float>:
$ diff main.cpp maincore.cpp
37c37,39
< typedef CGAL::Quotient<CGAL::MP_Float> ENT;
> #include <CGAL/CORE_Expr.h>
> typedef CORE::Expr ENT;
Remember to add support for CORE, e.g. with:
$ cgal_create_CMakeLists -c Core
Here is the correct circumcenter:
$ ./maincore | grep "circle 14"
circle 14: -0.104718 11.9295
Best,
Panos
Here is maincore.cpp:
#include <iostream>
//OTHER TYPES THAT ALSO FAIL:
#include <CGAL/MP_Float.h>
#include <CGAL/Simple_cartesian.h>
#include <CGAL/Segment_Delaunay_graph_traits_2.h>
#include <CGAL/Segment_Delaunay_graph_2.h>
typedef CGAL::Simple_cartesian<ENT > CK;
typedef
CGAL::Segment_Delaunay_graph_traits_without_intersections_2<CK,CGAL::Integral_domain_without_division_tag>
Gt;
typedef CGAL::Segment_Delaunay_graph_2<Gt> SDG_2;
#include <CGAL/Filtered_kernel.h>
#include <CGAL/Quotient.h>
typedef CGAL::Lazy_exact_nt<CGAL::Quotient<CGAL::MP_Float> > LENT;
typedef CGAL::Simple_cartesian<LENT> CK;
typedef
Gt;
#include <CGAL/Segment_Delaunay_graph_filtered_traits_2.h>
typedef CGAL::Simple_cartesian<double> CK;
typedef CGAL::Simple_cartesian<ENT> EK;
typedef
CGAL::Segment_Delaunay_graph_filtered_traits_2<CK,CGAL::Field_with_sqrt_tag,
EK, CGAL::Field_tag> Gt;
typedef SDG_2::Point_2 Point2;
int main(int argc, char *argv[]){
//THESE ARE FORE TEST OF CIRCUMCENTER
const int testSize=10;
Point2 ptData[testSize]={
Point2(-0.7204357120380354 ,13.89277201765595),
Point2(-0.7204357120380394 ,12.40288551592062),
Point2(-3.471103184719311 ,12.40288551592062),
Point2(-3.471103184719311 ,11.4560803911127),
Point2(-0.7204357120380394 ,11.4560803911127),
Point2(-0.7204357120380394 ,11.1683175492763),
Point2(-1.27464817265971 ,11.1683175492763),
Point2(-1.27464817265971 ,8.270305214503029),
Point2(0.6719538274731851 ,8.270305214503029),
Point2(0.6719538274731853 ,13.89277201765595),
SDG_2 sdg;
//create segment sites for the closed polygon with the points as
vertices
std::cout<< "Calculating Segment Delaunay:"<<std::endl;
for (int i = 0; i < testSize; ++i) {
std::cout<< "processing "<< i <<" of "<<testSize << std::endl;
int next = (i + 1) % testSize;
const SDG_2::Site_2
&site=SDG_2::Site_2::construct_site_2(ptData[i], ptData[next]);
sdg.insert(site);
std::cout<<std::endl;
std::cout<< "Testing Circumcenter (Primal):"<<std::endl;
int circNum=0;
for(auto fit=sdg.finite_faces_begin(); fit!= sdg.finite_faces_end();
++fit){
Point2 center = sdg.primal(fit);
std::cout<<"circle "<< circNum++ <<": "<<center<<std::endl;
std::cout<< "Done " << std::endl;
- [cgal-discuss] Segment Delaunay, error finding circumcenter of face., Pablo Miranda Carranza, 05/02/2013
- Re: [cgal-discuss] Segment Delaunay, error finding circumcenter of face., Panagiotis Cheilaris, 05/02/2013
- [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Pablo Miranda Carranza, 05/02/2013
- [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Pablo Miranda Carranza, 05/03/2013
- Re: [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Panagiotis Cheilaris, 05/03/2013
- [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Pablo Miranda Carranza, 05/06/2013
- [cgal-discuss] CGAL on building models, Cody Rose, 05/06/2013
- Re: [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Panagiotis Cheilaris, 05/07/2013
- [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Pablo Miranda Carranza, 05/08/2013
- Re: [cgal-discuss] Re: Segment Delaunay, error finding circumcenter of face., Panagiotis Cheilaris, 05/08/2013
