- To:
- Subject: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation
- Date: Wed, 15 May 2013 15:19:20 +0200
On 05/15/2013 03:02 PM, Yohann wrote:
Hi,What is the Kernel are you using? Do you have a minimal example showing the pb?
The documentation of the 2D Delaunay triangulation states that the class deals
with duplicate points properly (see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Delaunay_triangulation_2.html#Index_anchor_1651).
The documentation of the *constrained* 2D delaunay triangulation doesn't claim
anything about this (see
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Constrained_Delaunay_triangulation_2.html#Index_anchor_1646).
Does it mean the client has to make sur never to insert point twice?
The reason I am asking is because I have a case where the constrained
triangulation deals fine with multiple insertions of the same point and cases
where it crashes. Is it that I am lucky sometimes or that I should fill a bug
report ?
Sebastien.
Thanks for your time.
- [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/15/2013
- Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/15/2013
- Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/15/2013
- Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/15/2013
- Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/16/2013
- Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/16/2013
- Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/16/2013
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/16/2013
