cgal-discuss - Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation
  • To:
  • Subject: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation
  • Date: Thu, 16 May 2013 17:13:38 +0200
Could you try with CGAL::No_intersection_tag ?
Sebastien.
On 05/16/2013 03:14 PM, Yohann wrote:
Turns out the minimal example is hard to build. I'm still working on it.
What I have so far boils down to the following steps:
for each polygon (list of (x,y)) of some list (many thousands)
instanciate a contrained 2d triangulation
insert the points in it
end
This crashes when the iteration reaches a specific polygon (that has a
duplicated point, but it's not the first polygon alike encountered during the
iteration). Somehow, if I start the iteration straight at this polygon,
everything goes fine, which is weird because the triangulation object is
reinstanciated after each iteration anyway.
If I remove all the polygons that have a duplicated point before hand, there's
no crash at all (basically, it also works if I only remove the very polygon
that crashes the for loop).
I'm well aware this is not helping you much, I was hoping it might give you a
clue of what is happening that would point me in a relevant direction towards
a minimal example.
Here's the kernel and general configuration that I am using though:
typedef CGAL::Exact_predicates_inexact_constructions_kernel T_CgalKernel;
typedef CGAL::Triangulation_vertex_base_2<T_CgalKernel>
T_TriangulationVb;
typedef CGAL::Constrained_triangulation_face_base_2<T_CgalKernel>
T_TriangulationFb;
typedef
CGAL::Triangulation_data_structure_2<T_TriangulationVb,T_TriangulationFb>
T_TriangulationTds;
typedef CGAL::Exact_predicates_tag T_TriangulationItag;
typedef
CGAL::Constrained_Delaunay_triangulation_2<T_CgalKernel,T_TriangulationTds,T_TriangulationItag>
T_Triangulation;
I'll come back to you when I have something that doesn't involve 55000 polygon
insertions before crashing.
Thanks
