Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation
- To:
- Subject: Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation
- Date: Thu, 16 May 2013 18:05:51 +0200
Le jeudi 16 mai 2013 15:14:33 Yohann a écrit :
> typedef
> CGAL::Constrained_Delaunay_triangulation_2<T_CgalKernel,T_TriangulationTds,T
> _TriangulationItag> T_Triangulation;
Here you should probably use that:
typedef CGAL::Constrained_Delaunay_triangulation_2<
T_CgalKernel,
T_TriangulationTds,
T_TriangulationItag
> T_Triangulation_base;
typedef CGAL::Constrained_triangulation_plus_2<T_Triangulation_base>
The template class Constrained_triangulation_plus_2 behaves like the Cdt
template class, but handles a hierarchy of constraints. And if a constraint
is
inserted twice (even in a different orientation), it does not try to compute
twice the intersections with the other constraints. That could fix your
issues, if my guess is right.
Laurent Rineau, PhD
- [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/15/2013
- Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/15/2013
- Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/15/2013
- Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/15/2013
- Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Yohann, 05/16/2013
- Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Sebastien Loriot (GeometryFactory), 05/16/2013
- Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/16/2013
- Re: Re: Re: Re: Re: Re: [cgal-discuss] Point duplicates in a constrained 2D Delaunay Triangulation, Laurent Rineau (CGAL/GeometryFactory), 05/16/2013
