cgal-discuss - [cgal-discuss] Re: Nef polygon
  • To:
  • Subject: [cgal-discuss] Re: Nef polygon
  • Date: Thu, 16 May 2013 07:55:14 -0700 (PDT)
Hello Sebastien:
I try you give the example, but I am confused about the .off format.
Since I am a newer CGAL User, as my understanding, .off format file store
the points. So I use the.txt format instead of .off format.
As the picture I show you , I get two half sphere intersect. I use
Delaunay Triangulation to triangulate the intersected point(red points) and
the left outside point(left while points), at the same time , I triangulate
the intersected points and the right points.
but my final goal is take the " left ,intersected,and right points "as
the whole object. so I want to use the Boolean Opeation to union the whole
object .Then use the Delaunay Triangulation to triangulate the whole object.
If I don't triangulate twice times , the result can not meet my goal!
Do you have some good ideas to help me ? Thanks a lot!
<http://cgal-discuss.949826.n4.nabble.com/file/n4657467/IMG_20130515_222140.jpg>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4657467.html
