- To:
- Subject: Re: [cgal-discuss] Re: Nef polygon
- Date: Thu, 16 May 2013 17:14:46 +0200
Generate the off files and use the code I gave.
Sebastien.
On 05/16/2013 05:12 PM, ChaoM wrote:
Ah....
I see the webpage, you mean I must use the .off format to store the
points? Only in this way, I can get the infomation of point and the index?
I use the OpenGL to draw the result, So I need to know the index~~
Sebastien, since you know my final goal ,do you have any good solution to
solve my goal?
Thanks~
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4657471.html
- [cgal-discuss] Nef polygon, ChaoM, 05/15/2013
- Re: [cgal-discuss] Nef polygon, Sebastien Loriot (GeometryFactory), 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/16/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/17/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/17/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/20/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/20/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/21/2013
