- To:
- Subject: [cgal-discuss] Re: Nef polygon
- Date: Mon, 20 May 2013 07:44:45 -0700 (PDT)
Hello Sebastien:
I do as your suggestion! But when I convert the polyhedron to .off,
the result seems good ! While I compute the outside points and intersected
points , and do the Delaunay Triangulation, the result of converting .off
seems bad !
More detail ,please see the pictures ~
Thank you !
<http://cgal-discuss.949826.n4.nabble.com/file/n4657510/poly_.off.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657510/delaunay_to_.off.png>
<http://cgal-discuss.949826.n4.nabble.com/file/n4657510/Delaunay.png>
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Nef-polygon-tp4657453p4657510.html
- [cgal-discuss] Nef polygon, ChaoM, 05/15/2013
- Re: [cgal-discuss] Nef polygon, Sebastien Loriot (GeometryFactory), 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/16/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/16/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/17/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/17/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/20/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/20/2013
- [cgal-discuss] Re: Nef polygon, ChaoM, 05/21/2013
- Re: [cgal-discuss] Re: Nef polygon, Sebastien Loriot (GeometryFactory), 05/21/2013
