- To:
- Subject: Re: [cgal-discuss] difficulties with clang and c+11
- Date: Wed, 22 May 2013 21:14:32 +0200
On 22-05-13 10:37, Philipp Moeller wrote:
> Can you apply the following patch to
> Triangulation_line_face_circulator_2.h and check the result? I currently
> don't have access to an Apple version of clang to test this myself.
> diff --git
> a/Triangulation_2/include/CGAL/Triangulation_line_face_circulator_2.h
> b/Triangulation_2/include/CGAL/Triangulation_line_face_circulator_2.h
> index cc43e76..fd7b989 100644
> --- a/Triangulation_2/include/CGAL/Triangulation_line_face_circulator_2.h
> +++ b/Triangulation_2/include/CGAL/Triangulation_line_face_circulator_2.h
> @@ -93,7 +93,7 @@ public:
> Face* operator->() {return &*pos;}
> Face& operator*() { return *pos;}
> Face_handle handle() {return pos;}
> - operator const Face_handle() const {return pos;}
> + operator Face_handle() const {return pos;}
> bool operator==(const Line_face_circulator& lfc) const;
> bool operator!=(const Line_face_circulator& lfc) const;
> [...snipped rest of the message...]
Removal of const makes at least the compilation work,
but the linker complaines about:
ld: symbol(s) not found for architecture x86_64
clang: error: linker command failed with exit code 1 (use -v to see
invocation)
There seems to be unknown symbols called from CGAL, but also from other
object files.
What is causing this is not clear to me yet. The question is of course, is
this
still a CGAL problem? If not, i should not bother you with this, i guess.
Ruud
Full output:
openscad $ /usr/bin/clang++ -headerpad_max_install_names -arch x86_64
-Xarch_x86_64 -mmacosx-version-min=10.8 -o
OpenSCAD.app/Contents/MacOS/OpenSCAD objects/OffscreenContextCGL.o
objects/CocoaUtils.o objects/version_check.o objects/ProgressWidget.o
objects/mathc99.o objects/linalg.o objects/handle_dep.o objects/value.o
objects/expr.o objects/func.o objects/localscope.o objects/module.o
objects/node.o objects/context.o objects/modcontext.o objects/evalcontext.o
objects/csgterm.o objects/csgtermnormalizer.o objects/polyset.o
objects/csgops.o objects/transform.o objects/color.o objects/primitives.o
objects/loop.o objects/projection.o objects/cgaladv.o objects/surface.o
objects/control.o objects/render.o objects/dxfdata.o objects/dxfdim.o
objects/linearextrude.o objects/rotateextrude.o objects/loopextrude.o
objects/printutils.o objects/fileutils.o objects/progress.o
objects/parsersettings.o objects/stl-utils.o objects/boost-utils.o
objects/nodedumper.o objects/traverser.o objects/PolySe
t
Evaluator.o objects/ModuleCache.o objects/PolySetCache.o objects/Tree.o
objects/rendersettings.o objects/highlighter.o objects/Preferences.o
objects/OpenCSGWarningDialog.o objects/editor.o objects/GLView.o
objects/QGLView.o objects/AutoUpdater.o objects/builtin.o objects/export.o
objects/export_png.o objects/import.o objects/renderer.o
objects/ThrownTogetherRenderer.o objects/dxftess.o objects/CSGTermEvaluator.o
objects/svg.o objects/OffscreenView.o objects/fbo.o objects/system-gl.o
objects/imageutils.o objects/lodepng.o objects/openscad.o objects/mainwin.o
objects/imageutils-macosx.o objects/OpenCSGRenderer.o objects/cgalutils.o
objects/CGALEvaluator.o objects/PolySetCGALEvaluator.o objects/CGALCache.o
objects/CGALRenderer.o objects/CGAL_Nef_polyhedron.o
objects/CGAL_Nef_polyhedron_DxfData.o objects/cgaladv_minkowski2.o
objects/cgalworker.o objects/AppleEvents.o objects/lexer.lexer.o
objects/parser_yacc.o objects/moc_ProgressWidget.o objects/moc_QGLView.o
objects/moc_MainWindow.o ob
j
ects/moc_Preferences.o objects/moc_OpenCSGWarningDialog.o
objects/moc_AboutDialog.o objects/moc_editor.o objects/moc_cgalworker.o
objects/moc_EventFilter.o objects/qrc_openscad.o
-F/opt/local/Library/Frameworks -F/opt/local/lib -framework Cocoa -lgmp
-lmpfr -lCGAL -lopencsg -lGLEW -lboost_thread-mt -lboost_program_options-mt
-lboost_filesystem-mt -lboost_system-mt -lboost_regex-mt
-F/opt/local/Library/Frameworks -F/opt/local/lib -L/opt/local/lib -framework
QtOpenGL -framework QtGui -framework QtCore -framework OpenGL -framework AGL
-v
Apple LLVM version 4.2 (clang-425.0.28) (based on LLVM 3.2svn)
Target: x86_64-apple-darwin12.3.0
Thread model: posix
"/usr/bin/ld" -demangle -dynamic -arch x86_64 -headerpad_max_install_names
-macosx_version_min 10.8.0 -o OpenSCAD.app/Contents/MacOS/OpenSCAD
-L/opt/local/lib objects/OffscreenContextCGL.o objects/CocoaUtils.o
objects/version_check.o objects/ProgressWidget.o objects/mathc99.o
objects/linalg.o objects/handle_dep.o objects/value.o objects/expr.o
objects/func.o objects/localscope.o objects/module.o objects/node.o
c
ts/PolySetEvaluator.o objects/ModuleCache.o objects/PolySetCache.o
objects/Tree.o objects/rendersettings.o objects/highlighter.o
objects/Preferences.o objects/OpenCSGWarningDialog.o objects/editor.o
objects/GLView.o objects/QGLView.o objects/AutoUpdater.o objects/builtin.o
objects/export.o objects/export_png.o objects/import.o objects/renderer.o
objects/moc_MainW
i
ndow.o objects/moc_Preferences.o objects/moc_OpenCSGWarningDialog.o
objects/moc_EventFilter.o objects/qrc_openscad.o -framework Cocoa -lgmp
-lboost_filesystem-mt -lboost_system-mt -lboost_regex-mt -framework QtOpenGL
-framework QtGui -framework QtCore -framework OpenGL -framework AGL -lstdc++
-lSystem /usr/bin/../lib/clang/4.2/lib/darwin/libclang_rt.osx.a
Undefined symbols for architecture x86_64:
"save_framebuffer(OffscreenContext*, std::__1::basic_ostream<char,
std::__1::char_traits<char> >&)", referenced from:
OffscreenView::save(std::__1::basic_ostream<char,
std::__1::char_traits<char> >&) in OffscreenView.o
"write_png(std::ostream&, unsigned char*, int, int)", referenced from:
save_framebuffer(OffscreenContext*, std::ostream&) in
save_framebuffer_common(OffscreenContext*, std::ostream&) in
"CGAL::File_writer_OFF::write_header(std::__1::basic_ostream<char,
std::__1::char_traits<char> >&, unsigned long, unsigned long, unsigned long,
bool)", referenced from:
void
CGAL::generic_print_polyhedron<CGAL::Polyhedron_3<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::Polyhedron_items_3, CGAL::HalfedgeDS_default, std::__1::allocator<int>
>, CGAL::File_writer_OFF>(std::__1::basic_ostream<char,
CGAL::Polyhedron_3<CGAL::Cartesian<CGAL::Gmpq>, CGAL::Polyhedron_items_3,
CGAL::HalfedgeDS_default, std::__1::allocator<int> > const&,
CGAL::File_writer_OFF&) in export.o
"CGAL::is_binary(std::__1::basic_ios<char, std::__1::char_traits<char>
export_off(CGAL_Nef_polyhedron*, std::__1::basic_ostream<char,
std::__1::char_traits<char> >&) in export.o
"CGAL::is_pretty(std::__1::basic_ios<char, std::__1::char_traits<char>
"CGAL::operator>>(std::__1::basic_istream<char, std::__1::char_traits<char>
>&, CGAL::File_header_OFF&)", referenced from:
CGAL::Polyhedron_scan_OFF<CGAL::HalfedgeDS_default<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::I_Polyhedron_derived_items_3<CGAL::Polyhedron_items_3>,
>::operator()(CGAL::HalfedgeDS_default<CGAL::Cartesian<CGAL::Gmpq>,
std::__1::allocator<int> >&) in import.o
"boost::program_options::to_internal(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&)", referenced
std::__1::vector<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> >,
std::__1::allocator<std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > > >
boost::program_options::to_internal<std::__1::basic_string<char,
>(std::__1::vector<std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> >, std::__1::allocator<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > > > const&) in
openscad.o
"boost::program_options::options_description::options_description(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&, unsigned
int, unsigned int)", referenced from:
_main in openscad.o
"boost::program_options::invalid_option_value::invalid_option_value(std::__1::basic_string<char,
referenced from:
void boost::program_options::validate<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> >, char>(boost::any&,
std::__1::char_traits<char>, std::__1::allocator<char> > > > const&,
std::__1::char_traits<char>, std::__1::allocator<char> > > >*, int) in
openscad.o
"boost::program_options::detail::cmdline::cmdline(std::__1::vector<std::__1::basic_string<char,
std::__1::allocator<char> > > > const&)", referenced from:
boost::program_options::basic_command_line_parser<char>::basic_command_line_parser(int,
char const* const*) in openscad.o
"boost::program_options::validate(boost::any&,
std::__1::allocator<char> >*, int)", referenced from:
openscad.o
boost::program_options::typed_value<std::__1::basic_string<char,
char>::xparse(boost::any&, std::__1::vector<std::__1::basic_string<char,
std::__1::allocator<char> > > > const&) const in openscad.o
"OpenCSG::render(std::__1::vector<OpenCSG::Primitive*,
std::__1::allocator<OpenCSG::Primitive*> > const&)", referenced from:
OpenCSGRenderer::renderCSGChain(CSGChain*, int*, bool, bool) const in
OpenCSGRenderer.o
"boost::program_options::abstract_variables_map::operator[](std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) const",
referenced from:
get_camera(boost::program_options::variables_map) in openscad.o
_main in openscad.o
"boost::program_options::error_with_option_name::substitute_placeholders(std::__1::basic_string<char,
referenced from:
vtable for
boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::program_options::invalid_option_value>
> in openscad.o
vtable for
in openscad.o
vtable for boost::program_options::invalid_option_value in openscad.o
vtable for boost::program_options::validation_error in openscad.o
"boost::program_options::value_semantic_codecvt_helper<char>::parse(boost::any&,
std::__1::char_traits<char>, std::__1::allocator<char> > > > const&, bool)
const", referenced from:
vtable for
boost::program_options::typed_value<std::__1::vector<std::__1::basic_string<char,
std::__1::allocator<char> > > >, char> in openscad.o
vtable for
std::__1::char_traits<char>, std::__1::allocator<char> >, char> in openscad.o
"std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> >::find(char, unsigned long) const", referenced
boost::basic_format<char, std::__1::char_traits<char>,
std::__1::allocator<char> >::parse(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in value.o
int
boost::io::detail::upper_bound_from_fstring<std::__1::basic_string<char,
std::__1::ctype<char> >(std::__1::basic_string<char,
std::__1::allocator<char> >::value_type, std::__1::ctype<char> const&,
unsigned char) in value.o
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in func.o
int
unsigned char) in func.o
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in module.o
int
unsigned char) in module.o
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in context.o
std::__1::allocator<char> >::compare(char const*) const", referenced from:
std::__1::__wrap_iter<char const*>
boost::re_detail::re_is_set_member<std::__1::__wrap_iter<char const*>, char,
boost::regex_traits<char, boost::cpp_regex_traits<char> >, unsigned
int>(std::__1::__wrap_iter<char const*>, std::__1::__wrap_iter<char const*>,
boost::re_detail::re_set_long<unsigned int> const*,
boost::re_detail::regex_data<char, boost::regex_traits<char,
boost::cpp_regex_traits<char> > > const&, bool) in handle_dep.o
Expression::evaluate(Context const*) const in expr.o
Expression::toString() const in expr.o
DxfData::DxfData(double, double, double, std::__1::basic_string<char,
std::__1::allocator<char> > const&, double, double, double) in dxfdata.o
builtin_dxf_dim(Context const*, EvalContext const*) in dxfdim.o
builtin_dxf_cross(Context const*, EvalContext const*) in dxfdim.o
LinearExtrudeModule::instantiate(Context const*, ModuleInstantiation
const*, EvalContext const*) const in linearextrude.o
"std::__1::__vector_base_common<true>::__throw_length_error() const",
referenced from:
std::__1::enable_if<__is_forward_iterator<boost::sub_match<std::__1::__wrap_iter<char
const*> >*>::value, void>::type
std::__1::vector<boost::sub_match<std::__1::__wrap_iter<char const*> >,
std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char const*> > >
>::assign<boost::sub_match<std::__1::__wrap_iter<char const*>
>*>(boost::sub_match<std::__1::__wrap_iter<char const*> >*,
boost::sub_match<std::__1::__wrap_iter<char const*> >*) in handle_dep.o
void
std::__1::vector<boost::re_detail::recursion_info<boost::match_results<std::__1::__wrap_iter<char
const*>, std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char
const*> > > > >,
std::__1::allocator<boost::re_detail::recursion_info<boost::match_results<std::__1::__wrap_iter<char
const*> > > > > >
>::__push_back_slow_path<boost::re_detail::recursion_info<boost::match_results<std::__1::__wrap_iter<char
const*> > > > >
>(boost::re_detail::recursion_info<boost::match_results<std::__1::__wrap_iter<char
const*> > > > >&&) in handle_dep.o
>::vector(std::__1::vector<boost::sub_match<std::__1::__wrap_iter<char
const*> >, std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char
const*> > > > const&) in handle_dep.o
>::insert(std::__1::__wrap_iter<boost::sub_match<std::__1::__wrap_iter<char
const*> > const*>, unsigned long, boost::sub_match<std::__1::__wrap_iter<char
const*> > const&) in handle_dep.o
boost::re_detail::basic_regex_formatter<boost::re_detail::string_out_iterator<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > >,
boost::match_results<std::__1::__wrap_iter<char const*>,
>, boost::regex_traits_wrapper<boost::regex_traits<char,
boost::cpp_regex_traits<char> > >, char const*>::toi(char const*&, char
const*, int, mpl_::bool_<false> const&) in handle_dep.o
void std::__1::vector<Value, std::__1::allocator<Value>
>::__push_back_slow_path<Value>(Value&&) in value.o
>::vector(std::__1::vector<Value, std::__1::allocator<Value> > const&) in
value.o
"std::__1::__vector_base_common<true>::__throw_out_of_range() const",
referenced from:
PolySet::dump() const in polyset.o
PolySet::render_surface(PolySet::csgmode_e, Eigen::Transform<double, 3,
2, 0> const&, int*) const in polyset.o
PolySet::render_edges(PolySet::csgmode_e) const in polyset.o
CGAL_Build_PolySet::operator()(CGAL::HalfedgeDS_default<CGAL::Cartesian<CGAL::Gmpq>,
std::__1::allocator<int> >&) in cgalutils.o
"std::__1::__basic_string_common<true>::__throw_length_error() const",
referenced from:
std::__1::basic_stringbuf<char, std::__1::char_traits<char>,
std::__1::allocator<char> >::str() const in handle_dep.o
std::__1::allocator<char> >::str() const in value.o
std::__1::allocator<char> >::str() const in expr.o
std::__1::allocator<char> >::str() const in func.o
std::__1::allocator<char> >::str() const in localscope.o
std::__1::allocator<char> >::str() const in module.o
std::__1::allocator<char> >::str() const in csgterm.o
"std::__1::locale::has_facet(std::__1::locale::id&) const", referenced from:
std::__1::basic_filebuf<char, std::__1::char_traits<char>
>::basic_filebuf() in surface.o
>::basic_filebuf() in dxfdata.o
>::basic_filebuf() in ModuleCache.o
>::basic_filebuf() in import.o
>::basic_filebuf() in imageutils.o
>::basic_filebuf() in lodepng.o
>::basic_filebuf() in openscad.o
"std::__1::locale::use_facet(std::__1::locale::id&) const", referenced from:
std::__1::basic_ostream<char, std::__1::char_traits<char> >&
std::__1::operator<<<std::__1::char_traits<char>
>(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, char const*)
in handle_dep.o
std::__1::operator<<<char, std::__1::char_traits<char>,
std::__1::allocator<char> >(std::__1::basic_ostream<char,
std::__1::char_traits<char> >&, std::__1::basic_string<char,
handle_dep.o
>(std::__1::basic_ostream<char, std::__1::char_traits<char> >&, char) in
value.o
in value.o
void boost::io::detail::put<char, std::__1::char_traits<char>,
std::__1::allocator<char>, double const&>(double const&,
boost::io::detail::format_item<char, std::__1::char_traits<char>,
std::__1::allocator<char> > const&, boost::basic_format<char,
std::__1::char_traits<char>, std::__1::allocator<char> >::string_type&,
std::__1::allocator<char> >::internal_streambuf_t&, std::__1::locale*) in
value.o
std::__1::allocator<char> >::make_or_reuse_data(unsigned long) in value.o
"std::__1::locale::operator==(std::__1::locale const&) const", referenced
bool boost::detail::lcast_ret_float<std::__1::char_traits<char>,
double, char>(double&, char const*, char const*) in surface.o
double, char>(double&, char const*, char const*) in dxfdata.o
bool boost::detail::lcast_ret_unsigned<std::__1::char_traits<char>,
unsigned int, char>(unsigned int&, char const*, char const*) in dxfdata.o
double, char>(double&, char const*, char const*) in import.o
unsigned int, char>(unsigned int&, char const*, char const*) in openscad.o
double, char>(double&, char const*, char const*) in openscad.o
double, char>(double&, char const*, char const*) in lexer.lexer.o
"std::__1::ios_base::getloc() const", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
value.o
boost::io::detail::stream_format_state<char,
std::__1::char_traits<char> >::apply_on(std::__1::basic_ios<char,
std::__1::char_traits<char> >&, std::__1::locale*) const in value.o
"std::logic_error::logic_error(char const*)", referenced from:
>::raise_logic_error() in handle_dep.o
>::raise_logic_error() in import.o
boost::re_detail::perl_matcher<std::__1::__wrap_iter<char const*>,
std::__1::allocator<boost::sub_match<std::__1::__wrap_iter<char const*> > >,
>::construct_init(boost::basic_regex<char, boost::regex_traits<char,
boost::regex_constants::_match_flags) in handle_dep.o
boost::regex_constants::_match_flags) in import.o
"std::logic_error::logic_error(std::logic_error const&)", referenced from:
void boost::throw_exception<std::logic_error>(std::logic_error const&)
in handle_dep.o
boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::logic_error>
>::clone_impl(boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::logic_error>
> const&,
>::clone_tag) in handle_dep.o
>::clone_impl(boost::exception_detail::error_info_injector<std::logic_error>
void
boost::throw_exception<std::invalid_argument>(std::invalid_argument const&)
in handle_dep.o
boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::invalid_argument>
>::clone_impl(boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<std::invalid_argument>
> const&,
"std::range_error::~range_error()", referenced from:
CGAL::Uncertain_conversion_exception::~Uncertain_conversion_exception()
in export.o
in export.o
bool
CGAL::Filtered_predicate<CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CommonKernelFunctors::Equal_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
CGAL::Cartesian_converter<CGAL::Type_equality_wrapper<CGAL::Cartesian_base_no_ref_count<double,
CGAL::Epick>, CGAL::Epick>, CGAL::Simple_cartesian<CGAL::Gmpq>,
CGAL::NT_converter<double, CGAL::Gmpq> >,
CGAL::Epick>, CGAL::Epick>, CGAL::Simple_cartesian<CGAL::Interval_nt<false>
>, CGAL::NT_converter<double, CGAL::Interval_nt<false> > >,
true>::operator()<CGAL::Point_2<CGAL::Epick>, CGAL::Point_2<CGAL::Epick>
>(CGAL::Point_2<CGAL::Epick> const&, CGAL::Point_2<CGAL::Epick> const&) const
in dxftess.o
in dxftess.o
in dxftess.o
CGAL::Sign
CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CartesianKernelFunctors::Orientation_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
true>::operator()<CGAL::Point_2<CGAL::Epick>, CGAL::Point_2<CGAL::Epick>,
CGAL::Point_2<CGAL::Epick> >(CGAL::Point_2<CGAL::Epick> const&,
in dxftess.o
CGAL::Angle
CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Angle_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CartesianKernelFunctors::Angle_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
in dxftess.o
"std::runtime_error::runtime_error(char const*)", referenced from:
boostfs_uncomplete(boost::filesystem::path, boost::filesystem::path) in
boost-utils.o
"std::runtime_error::runtime_error(std::__1::basic_string<char,
void
boost::re_detail::raise_error<boost::regex_traits_wrapper<boost::regex_traits<char,
>(boost::regex_traits_wrapper<boost::regex_traits<char,
boost::cpp_regex_traits<char> > > const&, boost::regex_constants::error_type)
in handle_dep.o
void
in import.o
std::__1::allocator<char> > > >, char>::notify(boost::any const&) const in
openscad.o
char>::notify(boost::any const&) const in openscad.o
CGAL::Equal_to<CGAL::Gmpq, CGAL::Gmpq>::result_type
CGAL::collinearC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&,
CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&,
CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&) in export.o
bool CGAL::operator==<CGAL::Simple_cartesian<CGAL::Interval_nt<false> >
>(CGAL::VectorC2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > > const&,
CGAL::VectorC2<CGAL::Simple_cartesian<CGAL::Interval_nt<false> > > const&) in
dxftess.o
CGAL::equal_planeC3<CGAL::Gmpq>(CGAL::Gmpq const&, CGAL::Gmpq const&,
CGAL::Gmpq const&, CGAL::Gmpq const&) in mainwin.o
CGAL::Gmpq const&, CGAL::Gmpq const&) in CGALEvaluator.o
CGAL::Gmpq const&, CGAL::Gmpq const&, CGAL::Gmpq const&) in CGALEvaluator.o
CGAL::Gmpq const&, CGAL::Gmpq const&) in PolySetCGALEvaluator.o
"std::runtime_error::runtime_error(std::runtime_error const&)", referenced
bool
in dxftess.o
CGAL::Sign
in dxftess.o
CGAL::Angle
in dxftess.o
CGAL::Sign
CGAL::Filtered_predicate<CGAL::CartesianKernelFunctors::Side_of_oriented_circle_2<CGAL::Simple_cartesian<CGAL::Gmpq>
CGAL::CartesianKernelFunctors::Side_of_oriented_circle_2<CGAL::Simple_cartesian<CGAL::Interval_nt<false>
>(CGAL::Point_2<CGAL::Epick> const&, CGAL::Point_2<CGAL::Epick> const&,
in dxftess.o
void
boost::throw_exception<boost::bad_function_call>(boost::bad_function_call
const&) in openscad.o
boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::bad_function_call>
>::clone_impl(boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::bad_function_call>
> const&,
>::clone_tag) in openscad.o
"std::invalid_argument::~invalid_argument()", referenced from:
void
in handle_dep.o
>::~clone_impl() in handle_dep.o
boost::exception_detail::error_info_injector<std::invalid_argument>::~error_info_injector()
in handle_dep.o
non-virtual thunk to
in handle_dep.o
std::__1::allocator<char> >::erase(unsigned long, unsigned long)", referenced
SurfaceNode::evaluate_polyset(PolySetEvaluator*) const in surface.o
void boost::algorithm::trim_right_if<std::__1::basic_string<char,
boost::algorithm::detail::is_classifiedF>(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> >&,
boost::algorithm::detail::is_classifiedF) in surface.o
boost::algorithm::detail::is_classifiedF) in dxfdata.o
NodeDumper::handleIndent(State const&) in nodedumper.o
NodeDumper::visit(State&, AbstractNode const&) in nodedumper.o
Tree::getIdString(AbstractNode const&) const in Tree.o
std::__1::allocator<char> >::__init(char const*, unsigned long)", referenced
boost::re_detail::cpp_regex_traits_implementation<char>::error_string(boost::regex_constants::error_type)
Value::Value(char const*) in value.o
boost::detail::variant::invoke_visitor<tostring_visitor
const>::result_type boost::detail::variant::visitation_impl<mpl_::int_<0>,
boost::detail::variant::visitation_impl_step<boost::mpl::l_iter<boost::mpl::l_item<mpl_::long_<6l>,
boost::blank, boost::mpl::l_item<mpl_::long_<5l>, bool,
boost::mpl::l_item<mpl_::long_<4l>, double,
boost::mpl::l_item<mpl_::long_<3l>, std::__1::basic_string<char,
boost::mpl::l_item<mpl_::long_<2l>, std::__1::vector<Value,
std::__1::allocator<Value> >, boost::mpl::l_item<mpl_::long_<1l>,
Value::RangeType, boost::mpl::l_end> > > > > > >,
boost::mpl::l_iter<boost::mpl::l_end> >,
boost::detail::variant::invoke_visitor<tostring_visitor const>, void const*,
boost::variant<boost::blank, bool, double, std::__1::basic_string<char,
std::__1::vector<Value, std::__1::allocator<Value> >, Value::RangeType,
boost::detail::variant::void_, boost::deta
i
l::variant::void_, boost::detail::variant::void_,
boost::detail::variant::void_, boost::detail::variant::void_,
boost::detail::variant::void_>::has_fallback_type_>(int, int,
boost::detail::variant::invoke_visitor<tostring_visitor const>&, void const*,
mpl_::bool_<false>, boost::variant<boost::blank, bool, double,
std::__1::allocator<char> >, std::__1::vector<Value,
_
, boost::detail::variant::void_, boost::detail::variant::void_,
boost::detail::variant::void_>::has_fallback_type_, mpl_::int_<0>*,
boost::mpl::l_iter<boost::mpl::l_end> >*) in value.o
std::__1::allocator<char> >::basic_format(char const*) in value.o
Expression::Expression(Value const&) in expr.o
std::__1::allocator<char> >::basic_format(char const*) in func.o
std::__1::allocator<char> >::__init(char const*, unsigned long, unsigned
long)", referenced from:
ModuleInstantiation::dump(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) const in
module.o
Module::dump(std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > const&, std::__1::basic_string<char,
module.o
OpenSCAD::dump_cgal_nef_polyhedron2_face_svg(CGAL::CircFromIt<CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::Nef_halfedge_2<CGAL::HalfedgeDS_list_types<CGAL::Nef_polyhedron_2_rep<CGAL::Extended_cartesian<CGAL::Gmpq>,
CGAL::HDS_items, bool>::HDS_traits, CGAL::HDS_items,
std::__1::allocator<int> >,
CGAL::HDS_items, bool>::HDS_traits> >,
std::__1::allocator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::Nef_halfedge_2<CGAL::HalfedgeDS_list_types<CGAL::Nef_polyhedron_2_rep<CGAL::Extended_cartesian<CGAL::Gmpq>,
CGAL::HDS_items, bool>::HDS_traits> > > >,
CGAL::move_halfedge_around_face<CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::Nef_halfedge_2<CGAL::HalfedgeDS_list_types<CGAL::Nef_polyhed
r
on_2_rep<CGAL::Extended_cartesian<CGAL::Gmpq>, CGAL::HDS_items,
bool>::HDS_traits, CGAL::HDS_items, std::__1::allocator<int> >,
CGAL::HDS_items, bool>::HDS_traits> > > > > >,
CGAL::move_halfedge_around_face<CGAL::internal::In_place_list_const_iterator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::Nef_halfedge_2<CGAL::HalfedgeDS_list_types<CGAL::Nef_polyhedron_2_rep<CGAL::Extended_cartesian<CGAL::Gmpq>,
S
CGAL::PM_explorer<CGAL::PM_const_decorator<CGAL::HalfedgeDS_default<CGAL::Nef_polyhedron_2_rep<CGAL::Extended_cartesian<CGAL::Gmpq>,
std::__1::allocator<int> > >, CGAL::Extended_cartesian<CGAL::Gmpq> >, bool,
bool) in svg.o
_main in openscad.o
std::__1::allocator<char> > > >, char>::name() const in openscad.o
std::__1::char_traits<char>, std::__1::allocator<char> >, char>::name() const
in openscad.o
std::__1::allocator<char> >::__init(unsigned long, char)", referenced from:
Value::Value(char) in value.o
bracket_visitor::operator()(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&, double
const&) const in value.o
std::__1::allocator<char> >::append(char const*)", referenced from:
AbstractNode::toString() const in node.o
AbstractIntersectionNode::toString() const in node.o
CsgNode::toString() const in csgops.o
print_messages_pop() in printutils.o
PRINT(std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > const&) in printutils.o
std::__1::allocator<char> >::append(char const*, unsigned long)", referenced
value.o
void boost::io::detail::mk_str<char, std::__1::char_traits<char>,
std::__1::allocator<char> >(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> >&, char const*,
std::__1::allocator<char> >::size_type, long, char, unsigned int, char, bool)
in value.o
std::__1::allocator<char>, Value const&>(Value const&,
func.o
in func.o
std::__1::allocator<char>, std::__1::basic_string<char,
const&>(std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > const&, boost::io::detail::format_item<char,
std::__1::allocator<char> >::string_type&, boost::basic_format<char,
>::internal_streambuf_t&, std::__1::locale*) in func.o
func.o
std::__1::allocator<char> >::append(unsigned long, char)", referenced from:
boost::regex_replace<boost::re_detail::string_out_iterator<std::__1::basic_string<char,
std::__1::__wrap_iter<char const*>, boost::regex_traits<char,
boost::cpp_regex_traits<char> >, char, char
const*>(boost::re_detail::string_out_iterator<std::__1::basic_string<char,
boost::cpp_regex_traits<char> > > const&, char const*,
boost::cpp_regex_traits<char> > >, char const*>::put(char) in handle_dep.o
value.o
in value.o
func.o
in func.o
std::__1::allocator<char> >::assign(char const*)", referenced from:
module.o
Eigen::IOFormat::IOFormat(int, int, std::__1::basic_string<char,
std::__1::allocator<char> > const&) in csgterm.o
std::__1::allocator<char> > const&) in polyset.o
std::__1::allocator<char> > const&) in dxfdata.o
Builtins::initialize() in builtin.o
OpenSCAD::NefPoly3_dumper_svg::visit(CGAL::internal::In_place_list_const_iterator<CGAL::SNC_in_place_list_halffacet<CGAL::SNC_indexed_items::Halffacet<CGAL::SNC_structure<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool> > >,
std::__1::allocator<CGAL::SNC_in_place_list_halffacet<CGAL::SNC_indexed_items::Halffacet<CGAL::SNC_structure<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool> > > > >) in svg.o
glew_extensions_dump() in system-gl.o
std::__1::allocator<char> >::assign(char const*, unsigned long)", referenced
value.o
func.o
func.o
std::__1::allocator<char>, char&>(char&, boost::io::detail::format_item<char,
std::__1::allocator<char>, FileModule*&>(FileModule*&,
module.o
>::internal_streambuf_t&, std::__1::locale*) in module.o
std::__1::allocator<char> >::assign(unsigned long, char)", referenced from:
boost::cpp_regex_traits<char> > > const&, bool) in import.o
std::__1::allocator<char> >::insert(unsigned long, char const*, unsigned
QGLView::getRendererInfo() const in QGLView.o
std::__1::allocator<char> >::resize(unsigned long, char)", referenced from:
std::__1::allocator<char> >::overflow(int) in handle_dep.o
std::__1::allocator<char> >::str(std::__1::basic_string<char,
handle_dep.o
std::__1::allocator<char> >::clear() in value.o
value.o
in value.o
std::__1::allocator<char> >::overflow(int) in value.o
std::__1::allocator<char> >::reserve(unsigned long)", referenced from:
in value.o
in func.o
in module.o
std::__1::allocator<char> >::__grow_by(unsigned long, unsigned long, unsigned
long, unsigned long, unsigned long, unsigned long)", referenced from:
std::__1::enable_if<__is_forward_iterator<std::__1::__wrap_iter<char
const*> >::value, std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> >&>::type std::__1::basic_string<char,
>::append<std::__1::__wrap_iter<char const*> >(std::__1::__wrap_iter<char
const*>, std::__1::__wrap_iter<char const*>) in value.o
const*>, std::__1::__wrap_iter<char const*>) in func.o
const*>, std::__1::__wrap_iter<char const*>) in module.o
const*>, std::__1::__wrap_iter<char const*>) in context.o
const*>, std::__1::__wrap_iter<char const*>) in modcontext.o
const*>, std::__1::__wrap_iter<char const*>) in evalcontext.o
const*>, std::__1::__wrap_iter<char const*>) in csgtermnormalizer.o
std::__1::allocator<char> >::push_back(char)", referenced from:
std::__1::allocator<char> >::overflow(int) in expr.o
std::__1::allocator<char> >::overflow(int) in func.o
std::__1::allocator<char> >::overflow(int) in localscope.o
std::__1::allocator<char> >::overflow(int) in module.o
std::__1::allocator<char> >::basic_string(std::__1::basic_string<char,
handle_dep(std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > const&) in handle_dep.o
std::__1::pair<boost::unordered::iterator_detail::iterator<boost::unordered::detail::ptr_node<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > > >, bool>
boost::unordered::detail::table_impl<boost::unordered::detail::set<std::__1::allocator<std::__1::basic_string<char,
std::__1::allocator<char> >, boost::hash<std::__1::basic_string<char,
std::__1::equal_to<std::__1::basic_string<char, std::__1::char_traits<char>,
std::__1::allocator<char> > > > >::emplace_impl<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&&&) in
handle_dep.o
operator<<(std::__1::basic_ostream<char, std::__1::char_traits<char>
>&, Filename const&) in value.o
Value::Value(std::__1::basic_string<char, std::__1::char_traits<char>,
void boost::variant<boost::blank, bool, double,
boost::detail::variant::void_>::assigner::assign_impl<std::__1::basic_string<char,
std::__1::allocator<char> > const&, mpl_::bool_<false>, mpl_::bool_<false>,
mpl_::bool_<true>) in value.o
long, unsigned long, std::__1::allocator<char> const&)", referenced from:
PolySetEvaluator::getPolySet(AbstractNode const&, bool) in
PolySetEvaluator.o
CGALCache::get(std::__1::basic_string<char,
CGALCache.o
CGALCache::insert(std::__1::basic_string<char,
CGAL_Nef_polyhedron const&) in CGALCache.o
>&, Value const&) in value.o
>&, Value const&) in expr.o
>&, Value const&) in func.o
>&, Value const&) in context.o
>&, Value const&) in modcontext.o
>&, Value const&) in evalcontext.o
std::__1::allocator<char> >::~basic_string()", referenced from:
std::__1::basic_stringstream<char, std::__1::char_traits<char>,
std::__1::allocator<char> >::~basic_stringstream() in handle_dep.o
void
in handle_dep.o
non-virtual thunk to std::__1::basic_stringstream<char,
std::__1::allocator<char> >::operator=(std::__1::basic_string<char,
handle_dep.o
boost::detail::variant::assign_storage::result_type
boost::detail::variant::assign_storage, void*, boost::variant<boost::blank,
bool, double, std::__1::basic_string<char, std::__1::char_traits<char>,
s
boost::detail::variant::assign_storage&, void*, mpl_::bool_<false>,
a
std::__1::allocator<char> >::operator=(boost::io::detail::format_item<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in expr.o
"std::__1::basic_istream<char, std::__1::char_traits<char> >::get()",
referenced from:
CGAL::skip_until_EOL(std::__1::basic_istream<char,
std::__1::char_traits<char> >&) in import.o
"std::__1::basic_istream<char, std::__1::char_traits<char> >::read(char*,
read_stl_facet(std::__1::basic_ifstream<char,
std::__1::char_traits<char> >&, stl_facet&) in import.o
ImportNode::evaluate_polyset(PolySetEvaluator*) const in import.o
CGAL::File_scanner_OFF::scan_facet(unsigned long&, unsigned long) in
import.o
CGAL::File_scanner_OFF::scan_facet_vertex_index(unsigned long&,
unsigned long) in import.o
CGAL::File_scanner_OFF::scan_vertex(double&, double&, double&, double&)
in import.o
lodepng::load_file(std::__1::vector<unsigned char,
std::__1::allocator<unsigned char> >&, std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in lodepng.o
>::seekg(std::__1::fpos<__mbstate_t>)", referenced from:
"std::__1::basic_istream<char, std::__1::char_traits<char> >::seekg(long
long, std::__1::ios_base::seekdir)", referenced from:
"std::__1::basic_istream<char, std::__1::char_traits<char> >::tellg()",
referenced from:
"std::__1::basic_istream<char, std::__1::char_traits<char> >::ignore(long,
>::sentry::sentry(std::__1::basic_istream<char, std::__1::char_traits<char>
>&, bool)", referenced from:
std::__1::basic_istream<char, std::__1::char_traits<char> >&
std::__1::getline<char, std::__1::char_traits<char>,
std::__1::allocator<char> >(std::__1::basic_istream<char,
std::__1::char_traits<char>, std::__1::allocator<char> >&, char) in surface.o
std::__1::char_traits<char>, std::__1::allocator<char> >&, char) in dxfdata.o
std::__1::operator>><char, std::__1::char_traits<char>
>(std::__1::basic_istream<char, std::__1::char_traits<char> >&, char&) in
import.o
std::__1::char_traits<char>, std::__1::allocator<char> >&, char) in import.o
>::putback(char)", referenced from:
CGAL::File_scanner_OFF::skip_comment() in import.o
>::~basic_istream()", referenced from:
construction vtable for std::__1::basic_istream<char,
std::__1::char_traits<char> >-in-std::__1::basic_stringstream<char,
std::__1::char_traits<char>, std::__1::allocator<char> > in handle_dep.o
std::__1::char_traits<char>, std::__1::allocator<char> > in value.o
std::__1::char_traits<char>, std::__1::allocator<char> > in expr.o
std::__1::char_traits<char>, std::__1::allocator<char> > in func.o
std::__1::char_traits<char>, std::__1::allocator<char> > in localscope.o
std::__1::char_traits<char>, std::__1::allocator<char> > in module.o
std::__1::char_traits<char>, std::__1::allocator<char> > in csgterm.o
std::__1::basic_ifstream<char, std::__1::char_traits<char>
>::~basic_ifstream() in surface.o
non-virtual thunk to std::__1::basic_ifstream<char,
std::__1::char_traits<char> >::~basic_ifstream() in surface.o
>::~basic_ifstream() in dxfdata.o
>::operator>>(std::__1::basic_istream<char, std::__1::char_traits<char> >&
(*)(std::__1::basic_istream<char, std::__1::char_traits<char> >&))",
referenced from:
>::operator>>(double&)", referenced from:
in import.o
gl_version() in system-gl.o
>::operator>>(unsigned long&)", referenced from:
import.o
"std::__1::basic_ostream<char, std::__1::char_traits<char> >::put(char)",
referenced from:
CGAL::File_writer_OFF::write_footer() in export.o
CGAL::Polyhedron_incremental_builder_3<CGAL::HalfedgeDS_default<CGAL::Cartesian<CGAL::Gmpq>,
>::add_vertex(CGAL::Point_3<CGAL::Cartesian<CGAL::Gmpq> > const&) in export.o
std::__1::allocator<int> > >::begin_facet() in export.o
std::__1::allocator<int> > >::add_vertex_to_facet(unsigned long) in export.o
std::__1::allocator<int> > >::lookup_halfedge(unsigned long, unsigned long)
in export.o
>::lookup_hole(CGAL::internal::In_place_list_iterator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::I_Polyhedron_halfedge<CGAL::HalfedgeDS_halfedge_base<CGAL::HalfedgeDS_list_types<CGAL::Cartesian<CGAL::Gmpq>,
std::__1::allocator<int> >, CGAL::Boolean_tag<true>, CGAL::Boolean_tag<true>,
CGAL::Boolean_tag<true> > > >,
std::__1::allocator<CGAL::HalfedgeDS_in_place_list_halfedge<CGAL::I_Polyhedron_halfedge<CGAL::HalfedgeDS_halfedge_base<CGAL::HalfedgeDS_list_types<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::Boolean_tag<true> > > > > >) in export.o
CGAL::Constrained_triangulation_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
>, CGAL::Triangulation_ds_vertex_base_2<void> >,
CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
CGAL::Triangulation_face_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
>, CGAL::Triangulation_ds_face_base_2<void> > > >,
CGAL::No_intersection_tag>::intersect(CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Constrained_triangulation_face_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
CGAL::Triangulation_ds_face_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
r
tex_base_2<void> >,
>, CGAL::Triangulation_ds_face_base_2<void> > > > > > >, CGAL::Default>,
false>, int,
CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
CGAL::Triangulation_ds_vertex_base_2<CGAL::Triangulation_data_structure_2<CGAL::Triangulation_vertex_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq>
>, CGAL::Triangulation_ds_face_base_2<void> > > > > >, CGAL::Default>,
false>, CGAL::internal::CC_iterator<CGAL::Compact_container<CGAL::Triangula
t
ion_vertex_base_2<CGAL::Projection_traits_xy_3<CGAL::Cartesian<CGAL::Gmpq> >,
false>, CGAL::No_intersection_tag) in export.o
"std::__1::basic_ostream<char, std::__1::char_traits<char> >::flush()",
referenced from:
CGAL::Nef_polyhedron_3<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool>::is_simple() const in export.o
bool>::Build_polyhedron<CGAL::HalfedgeDS_default<CGAL::Cartesian<CGAL::Gmpq>,
>::Visitor::visit(CGAL::internal::In_place_list_const_iterator<CGAL::SNC_in_place_list_halffacet<CGAL::SNC_indexed_items::Halffacet<CGAL::SNC_structure<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool> > > > >) in export.o
in export.o
"std::__1::basic_ostream<char, std::__1::char_traits<char> >::write(char
const*, long)", referenced from:
void
CGAL::File_writer_OFF::write_vertex(double const&, double const&,
double const&) in export.o
lodepng::save_file(std::__1::vector<unsigned char,
std::__1::allocator<unsigned char> > const&, std::__1::basic_string<char,
write_bytes_to_ostream(void*, void const*, unsigned long) in
imageutils-macosx.o
CGAL::Nef::operator<<<CGAL::Gmpq>(std::__1::basic_ostream<char,
std::__1::char_traits<char> >&, CGAL::Nef::Polynomial<CGAL::Gmpq> const&) in
>::sentry::sentry(std::__1::basic_ostream<char, std::__1::char_traits<char>
in handle_dep.o
handle_dep.o
value.o
in value.o
in expr.o
>::sentry::~sentry()", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
in expr.o
>::~basic_ostream()", referenced from:
construction vtable for std::__1::basic_ostream<char,
std::__1::char_traits<char> >-in-boost::io::basic_oaltstringstream<char,
value.o
boost::io::basic_oaltstringstream<char, std::__1::char_traits<char>,
std::__1::allocator<char> >::~basic_oaltstringstream() in value.o
non-virtual thunk to boost::io::basic_oaltstringstream<char,
func.o
std::__1::allocator<char> >::~basic_oaltstringstream() in func.o
>::operator<<(void const*)", referenced from:
module.o
std::__1::allocator<char>, ModuleInstantiation const*&>(ModuleInstantiation
const*&, boost::io::detail::format_item<char, std::__1::char_traits<char>,
context.o
std::__1::allocator<char>, Context const*&>(Context const*&,
context.o
std::__1::allocator<char>, Context* const&>(Context* const&,
context.o
modcontext.o
modcontext.o
>::operator<<(std::__1::basic_streambuf<char, std::__1::char_traits<char>
ModuleCache::evaluate(std::__1::basic_string<char,
ModuleCache.o
>::operator<<(bool)", referenced from:
CgaladvNode::toString() const in cgaladv.o
DxfData::dump() const in dxfdata.o
r
S
bool) in svg.o
OpenSCAD::dump_svg(CGAL::Nef_polyhedron_2<CGAL::Extended_cartesian<CGAL::Gmpq>,
CGAL::HDS_items, bool> const&) in svg.o
OpenSCAD::dump_svg(CGAL::Nef_polyhedron_3<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool> const&) in svg.o
ZRemover::visit(CGAL::internal::In_place_list_const_iterator<CGAL::SNC_in_place_list_halffacet<CGAL::SNC_indexed_items::Halffacet<CGAL::SNC_structure<CGAL::Cartesian<CGAL::Gmpq>,
CGAL::SNC_indexed_items, bool> > > > >) in cgalutils.o
>::operator<<(double)", referenced from:
value.o
tostring_visitor::operator()(double const&) const in value.o
func.o
Eigen::internal::print_matrix<Eigen::Matrix<double, 4, 4, 0, 4, 4>
Eigen::Matrix<double, 4, 4, 0, 4, 4> const&, Eigen::IOFormat const&) in
csgterm.o
Eigen::internal::print_matrix<Eigen::Matrix<double, 1, 3, 1, 1, 3>
Eigen::Matrix<double, 1, 3, 1, 1, 3> const&, Eigen::IOFormat const&) in
polyset.o
PrimitiveNode::evaluate_polyset(PolySetEvaluator*) const in primitives.o
PrimitiveNode::toString() const in primitives.o
>::operator<<(float)", referenced from:
Eigen::internal::print_matrix<Eigen::Matrix<float, 4, 1, 0, 4, 1>
Eigen::Matrix<float, 4, 1, 0, 4, 1> const&, Eigen::IOFormat const&) in
csgterm.o
ColorNode::toString() const in color.o
std::__1::allocator<char>, float&>(float&,
color.o
>::operator<<(int)", referenced from:
Strip::print() in loop.o
ProjectionNode::toString() const in projection.o
std::__1::allocator<char>, int&>(int&, boost::io::detail::format_item<char,
>::internal_streambuf_t&, std::__1::locale*) in control.o
RenderNode::toString() const in render.o
>::operator<<(unsigned int)", referenced from:
check_fbo_status() in fbo.o
report_glerror(char const*) in system-gl.o
>::operator<<(long)", referenced from:
SurfaceNode::toString() const in surface.o
LinearExtrudeNode::toString() const in linearextrude.o
RotateExtrudeNode::toString() const in rotateextrude.o
std::__1::allocator<char>, long&>(long&, boost::io::detail::format_item<char,
>::internal_streambuf_t&, std::__1::locale*) in ModuleCache.o
ImportNode::toString() const in import.o
>::operator<<(unsigned long)", referenced from:
std::__1::allocator<char>, unsigned long&>(unsigned long&,
csgtermnormalizer.o
primitives.o
std::__1::allocator<char>, unsigned long const&>(unsigned long const&,
control.o
>::operator<<(long long)", referenced from:
std::__1::allocator<char>, long long&>(long long&,
ModuleCache.o
mainwin.o
"std::__1::basic_iostream<char, std::__1::char_traits<char>
>::~basic_iostream()", referenced from:
construction vtable for std::__1::basic_iostream<char,
"std::__1::basic_streambuf<char, std::__1::char_traits<char> >::sync()",
referenced from:
vtable for std::__1::basic_stringbuf<char, std::__1::char_traits<char>,
vtable for boost::io::basic_altstringbuf<char,
>::imbue(std::__1::locale const&)", referenced from:
"std::__1::basic_streambuf<char, std::__1::char_traits<char> >::uflow()",
referenced from:
>::setbuf(char*, long)", referenced from:
>::xsgetn(char*, long)", referenced from:
"std::__1::basic_streambuf<char, std::__1::char_traits<char> >::xsputn(char
>::showmanyc()", referenced from:
>::basic_streambuf()", referenced from:
tostring_visitor::operator()(std::__1::vector<Value,
std::__1::allocator<Value> > const&) const in value.o
AbstractFunction::dump(std::__1::basic_string<char,
std::__1::allocator<char> > const&) const in func.o
>::~basic_streambuf()", referenced from:
"std::__1::cerr", referenced from:
Vertex::specify(Vertex::VertexType, std::__1::vector<double,
std::__1::allocator<double> >) in loop.o
Edge::specify(Edge::EdgeType, Edge::TransType, std::__1::vector<double,
std::__1::allocator<double> >, std::__1::vector<Eigen::Matrix<double, 2, 1,
0, 2, 1>, Eigen::aligned_allocator<Eigen::Matrix<double, 2, 1, 0, 2, 1> > >)
in loop.o
"std::__1::cout", referenced from:
ZRemover::ZRemover() in PolySetCGALEvaluator.o
"std::__1::ctype<char>::id", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
value.o
"void std::__1::__sort<std::__1::__less<char, char>&, char*>(char*, char*,
std::__1::__less<char, char>&)", referenced from:
"std::__1::locale::classic()", referenced from:
"std::__1::locale::locale(std::__1::locale const&)", referenced from:
std::__1::vector<boost::io::detail::format_item<char,
std::__1::allocator<boost::io::detail::format_item<char,
>::__append(unsigned long, boost::io::detail::format_item<char,
std::__1::__split_buffer<boost::io::detail::format_item<char,
>&>::__construct_at_end(unsigned long, boost::io::detail::format_item<char,
>::__swap_out_circular_buffer(std::__1::__split_buffer<boost::io::detail::format_item<char,
std::__1::char_traits<char>, std::__1::allocator<char> > >&>&) in value.o
std::__1::char_traits<char>, std::__1::allocator<char> > > >::assign(unsigned
long, boost::io::detail::format_item<char, std::__1::char_traits<char>,
"std::__1::locale::locale()", referenced from:
std::__1::allocator<char> >::make_or_reuse_data(unsigned long) in func.o
std::__1::allocator<char> >::make_or_reuse_data(unsigned long) in module.o
"std::__1::locale::~locale()", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
const>::result_type
boost::detail::variant::visitation_impl_invoke_impl<boost::detail::variant::invoke_visitor<tostring_visitor
const>, void const*, Value::RangeType>(int,
Value::RangeType*, mpl_::bool_<true>) in value.o
std::__1::__vector_base<boost::io::detail::format_item<char,
>::~__vector_base() in value.o
value.o
"std::__1::locale::operator=(std::__1::locale const&)", referenced from:
std::__1::char_traits<char> >&, std::__1::locale*) const in func.o
std::__1::char_traits<char> >&, std::__1::locale*) const in module.o
std::__1::char_traits<char> >&, std::__1::locale*) const in context.o
"std::__1::codecvt<char, char, __mbstate_t>::id", referenced from:
>::imbue(std::__1::locale const&) in surface.o
>::imbue(std::__1::locale const&) in dxfdata.o
>::imbue(std::__1::locale const&) in ModuleCache.o
>::imbue(std::__1::locale const&) in import.o
"std::__1::ios_base::__set_badbit_and_consider_rethrow()", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
in expr.o
"std::__1::ios_base::init(void*)", referenced from:
>::basic_oaltstringstream(boost::io::basic_altstringbuf<char,
std::__1::char_traits<char>, std::__1::allocator<char> >*) in value.o
"std::__1::ios_base::clear(unsigned int)", referenced from:
in handle_dep.o
handle_dep.o
value.o
in value.o
in expr.o
"std::__1::ios_base::imbue(std::__1::locale const&)", referenced from:
std::__1::char_traits<char> >&, std::__1::locale*) const in modcontext.o
std::__1::char_traits<char> >&, std::__1::locale*) const in evalcontext.o
csgtermnormalizer.o
"std::__1::ios_base::iword(int)", referenced from:
"std::__1::numpunct<char>::id", referenced from:
"std::__1::basic_ios<char, std::__1::char_traits<char> >::~basic_ios()",
referenced from:
"std::bad_cast::bad_cast()", referenced from:
>::seekoff(long long, std::__1::ios_base::seekdir, unsigned int) in surface.o
std::__1::basic_filebuf<char, std::__1::char_traits<char> >::sync() in
surface.o
>::underflow() in surface.o
>::overflow(int) in surface.o
>::seekoff(long long, std::__1::ios_base::seekdir, unsigned int) in dxfdata.o
dxfdata.o
>::underflow() in dxfdata.o
boost::detail::lexical_cast_do_cast<int, std::__1::basic_string<char,
>::lexical_cast_impl(std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > const&) in dxfdata.o
boost::detail::lexical_cast_do_cast<double,
>::lexical_cast_impl(boost::sub_match<std::__1::__wrap_iter<char const*> >
const&) in import.o
_main in openscad.o
std::__1::allocator<char> > boost::any_cast<std::__1::basic_string<char,
std::__1::char_traits<char>, std::__1::allocator<char> > >(boost::any&) in
openscad.o
"std::bad_alloc::bad_alloc()", referenced from:
Eigen::internal::throw_std_bad_alloc() in primitives.o
Eigen::internal::throw_std_bad_alloc() in loop.o
Eigen::internal::throw_std_bad_alloc() in dxfdata.o
Eigen::internal::throw_std_bad_alloc() in CGAL_Nef_polyhedron_DxfData.o
"typeinfo for std::__1::basic_istream<char, std::__1::char_traits<char> >",
referenced from:
"typeinfo for std::__1::basic_ostream<char, std::__1::char_traits<char> >",
referenced from:
typeinfo for boost::io::basic_oaltstringstream<char,
"typeinfo for std::__1::basic_iostream<char, std::__1::char_traits<char>
>", referenced from:
typeinfo for std::__1::basic_stringstream<char,
"typeinfo for std::__1::basic_streambuf<char, std::__1::char_traits<char>
>", referenced from:
typeinfo for std::__1::basic_stringbuf<char,
typeinfo for boost::io::basic_altstringbuf<char,
"typeinfo for std::__1::ios_base::failure", referenced from:
GCC_except_table0 in imageutils-macosx.o
"vtable for std::__1::basic_ios<char, std::__1::char_traits<char> >",
referenced from:
std::__1::char_traits<char>, std::__1::allocator<char> >*) in func.o
std::__1::char_traits<char>, std::__1::allocator<char> >*) in module.o
std::__1::char_traits<char>, std::__1::allocator<char> >*) in context.o
std::__1::char_traits<char>, std::__1::allocator<char> >*) in modcontext.o
std::__1::char_traits<char>, std::__1::allocator<char> >*) in evalcontext.o
csgtermnormalizer.o
NOTE: a missing vtable usually means the first non-inline virtual member
function has no definition.
"non-virtual thunk to std::__1::basic_iostream<char,
std::__1::char_traits<char> >::~basic_iostream()", referenced from:
"non-virtual thunk to std::__1::basic_istream<char,
std::__1::char_traits<char> >::~basic_istream()", referenced from:
"non-virtual thunk to std::__1::basic_ostream<char,
std::__1::char_traits<char> >::~basic_ostream()", referenced from:
invocation)
- [cgal-discuss] difficulties with clang and c+11, Ruud Vlaming, 05/19/2013
- Re: [cgal-discuss] difficulties with clang and c+11, Philipp Moeller, 05/22/2013
- Re: Re: [cgal-discuss] difficulties with clang and c+11, Laurent Rineau (CGAL/GeometryFactory), 05/22/2013
- Re: [cgal-discuss] difficulties with clang and c+11, Ruud Vlaming, 05/22/2013
- Re: [cgal-discuss] difficulties with clang and c+11, Marc Glisse, 05/22/2013
- Re: [cgal-discuss] difficulties with clang and c+11, Ruud Vlaming, 05/23/2013
- Re: [cgal-discuss] difficulties with clang and c+11, Philipp Moeller, 05/23/2013
