cgal-discuss - Re: [cgal-discuss] Informations about Nearest Neighbour
  • To:
  • Subject: Re: [cgal-discuss] Informations about Nearest Neighbour
  • Date: Thu, 23 May 2013 07:12:50 +0200
On 05/23/2013 07:11 AM, Sebastien Loriot (GeometryFactory) wrote:
On 05/22/2013 02:19 PM,
wrote:
Hi,
You are on a mailing to help user of the CGAL library.
You will have chances to get an answer on a Matlab list.
... more chances ...
PS: I saw a message on the bindings list for which you got answer but no feedback from you. What did not work?
Sebastien.
I am working on a project in Java where I need to use the Nearest
Neighbour
function that exists in MatLab (since my project is basically a port of a
MatLab script). I need to compute the NN for set of points and a set
of faces
(triangles).
Using CGAL java bindings was the first option but I had issues getting
the
bindings to work and also I would have problems in deploying it to
different
platforms.
Could somebody please point me out to where I can learn how to do the
NN as in
MatLab's function [a b] = nearestNeighbor(..., .., .., ..);. ?
As input data I have an unsorted list of 3D triangles and as a result
I would
like to have the same result as the MatLab's function.
Any help pointing on an existing library for NN, or where I could
easily learn
how to do it, would be greatly appreciated
best regards
R.Bervini [% user.email %]
