- To:
- Subject: Re: [cgal-discuss] Informations about Nearest Neighbour
- Date: Thu, 23 May 2013 12:04:15 +0200
Il 23.05.2013 07:12, Sebastien Loriot (GeometryFactory) ha scritto:
On 05/23/2013 07:11 AM, Sebastien Loriot (GeometryFactory) wrote:
On 05/22/2013 02:19 PM,
wrote:
Hi,You are on a mailing to help user of the CGAL library.
You will have chances to get an answer on a Matlab list.
... more chances ...
PS: I saw a message on the bindings list for which you got answer but no feedback from you. What did not work?
Sebastien.
Thank you for your answer. Since MatLab uses CGAL I preferred to come and ask directly to the source, also an answer would be probably easier to get thru an open source project rather than in a commercial product. However I will try to ask there aswell.
Regarding the message on the bindings, I had no idea on how to compile, the step-by-step guide doesn't really explain what to do if you don't know the tools (I am still at the first step, cmake configuration) and the first answer was that it requires a steep learning curve. I only need a single functionality and I don't see the need to learn the whole compiling process.
And since there is no compiled version I understand I have to compile it myself depending on the system I'm working on, and that's not a possible option for me.
Thank you
Rasael
PS. Is there by any chance a java-bindings precompiled library for x86 (possibly x64) and MacOSX of any stable version of the bindings that supports triangulation and nearest neighbor?
- [cgal-discuss] Informations about Nearest Neighbour, rasael, 05/22/2013
- Re: [cgal-discuss] Informations about Nearest Neighbour, Sebastien Loriot (GeometryFactory), 05/23/2013
- Re: [cgal-discuss] Informations about Nearest Neighbour, Rasael Bervini Monkow, 05/23/2013
