- To:
- Subject: Re: [cgal-discuss] Re: update of power diagram vertices
- Date: Thu, 23 May 2013 07:15:28 +0200
On 05/21/2013 06:48 PM, liudaisuda wrote:
My last question here, hopefully it doesn't bother you. How can I test if a
vertex-handle is valid or not? I couldn't find the doc for vertex_handle and
thus, not sure whether there exists a is_valid() method for a vertex_handle.
You can compare number_of_hidden_vertices() before and after a modification.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657544.html
- Re: [cgal-discuss] Re: update of power diagram vertices, (continued)
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/23/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Olivier Devillers, 05/23/2013
