- To:
- Subject: Re: [cgal-discuss] Re: update of power diagram vertices
- Date: Thu, 23 May 2013 09:21:28 +0200
Le 5/23/13 7:18 AM, Sebastien Loriot (GeometryFactory) a écrit :
On 05/21/2013 06:48 PM, liudaisuda wrote:
My last question here, hopefully it doesn't bother you. How can I test if aNote that an alternative to the move is to use
vertex-handle is valid or not? I couldn't find the doc for vertex_handle and
thus, not sure whether there exists a is_valid() method for a vertex_handle.
remove and then insert.
There is a second optional parameter to insert which a guess of a Face_handle where the point should be that you can use to speed things up.
If you are increasing the weight, just insert using old point as an hint to speed up point location
(old point will be hidden)
- [cgal-discuss] Re: update of power diagram vertices, (continued)
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/23/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Olivier Devillers, 05/23/2013
