- To:
- Subject: Re: [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration
- Date: Wed, 29 May 2013 13:28:24 +0200
On 05/29/2013 12:57 PM, fmortari wrote:
Thank you for the reply! I was somehow understanding that this could be theJust in case you don't know, CMake is able to generate eclipse "projects" so if you try to generate one from a CGAL example
problem. What I am asking is if someone has Eclipse correctly configured
with CGAL on windows operating system since I cannot understand where I am
wrong and the tutorials I found online refer only to Visual Studio
configurations.
maybe you could compare what is done in this project that is not in
yours.
Sebastien.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-Eclipse-Windows-7-configuration-tp4657609p4657622.html
- [cgal-discuss] CGAL Eclipse Windows 7 configuration, fmortari, 05/28/2013
- Re: [cgal-discuss] CGAL Eclipse Windows 7 configuration, Sebastien Loriot (GeometryFactory), 05/29/2013
- [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration, fmortari, 05/29/2013
- Re: [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration, Sebastien Loriot (GeometryFactory), 05/29/2013
