- To:
- Subject: [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration
- Date: Wed, 29 May 2013 06:39:44 -0700 (PDT)
yes, I know. I am still not capable of running an example under eclipse. Mingw works fine, I tried with some other source code... if someone has a working project under eclipse please share with me! thanks in advance!
2013/5/29 Sebastien Loriot (GeometryFactory) [via cgal-discuss] <[hidden email]>
On 05/29/2013 12:57 PM, fmortari wrote:Just in case you don't know, CMake is able to generate eclipse
> Thank you for the reply! I was somehow understanding that this could be the
> problem. What I am asking is if someone has Eclipse correctly configured
> with CGAL on windows operating system since I cannot understand where I am
> wrong and the tutorials I found online refer only to Visual Studio
> configurations.
"projects" so if you try to generate one from a CGAL example
maybe you could compare what is done in this project that is not in
yours.
Sebastien.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/CGAL-Eclipse-Windows-7-configuration-tp4657609p4657622.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
http://cgal-discuss.949826.n4.nabble.com/CGAL-Eclipse-Windows-7-configuration-tp4657609p4657624.htmlIf you reply to this email, your message will be added to the discussion below:
Filippo Mortari
View this message in context: Re: CGAL Eclipse Windows 7 configuration
- [cgal-discuss] CGAL Eclipse Windows 7 configuration, fmortari, 05/28/2013
- Re: [cgal-discuss] CGAL Eclipse Windows 7 configuration, Sebastien Loriot (GeometryFactory), 05/29/2013
- [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration, fmortari, 05/29/2013
- Re: [cgal-discuss] Re: CGAL Eclipse Windows 7 configuration, Sebastien Loriot (GeometryFactory), 05/29/2013
