- To:
- Subject: Re: [cgal-discuss] constrained triangulation existance
- Date: Thu, 06 Jun 2013 11:53:37 +0200
The edges of a constrained Delaunay triangulation are in a superset of theThank you, Laurent, for the hint! I got the "insight" while writing the reply below - so I still send it to the list in case anybody cares. ;-)
constraint segments, and not in a subset.
But wouldn't still be the constrained triangulation a special case for the decision problem?
constained triangulation
set of points P, constraints C \subseteq P^2
wanted: constrained triangulation T \subset P^2 such that C \subset T
Doesn't this implicitly solve the following decision problem?
set of points P, all edges E \subseteq P^2 that don't cross with edges from C (i.e. the constraints)
decide: is there a triangulation T \subseteq E
(... such that also C \subset T)
So no, they are not the same as C \subset T is important for the constrained triangulation. If there is a constrained triangulation, there clearly is a triangulation but if there is none you can't say anything about a triangulation in general.
- [cgal-discuss] constrained triangulation existance, Winnie, 06/03/2013
- Re: [cgal-discuss] constrained triangulation existance, Laurent Rineau (CGAL/GeometryFactory), 06/04/2013
- Re: [cgal-discuss] constrained triangulation existance, Winnie, 06/06/2013
