cgal-discuss - Re: [cgal-discuss] Volume mesh from 3D image
  • To:
  • Subject: Re: [cgal-discuss] Volume mesh from 3D image
  • Date: Tue, 16 Jul 2013 11:19:29 +0200
Le mardi 16 juillet 2013 11:09:24 Kamal Shahim a écrit :
> Hello,
> I am trying to create a volumetric mesh from an inr 3D image.
> The idea is to create a volumetric mesh for patient faces.
> However, the quality of surface mesh on the skin is not as good as the
> surface skin obtained by using vtkcontour filter or vtkmarchingcubes. What
> is the best combination for the following parameters in order to have a
> smooth surface comparable to those obtained by the contour filters? the
> image pixel size is about 0.5 in each direction.
> facet_angle
> facet_size
> facet_distance
> cell_radius_edge_ratio
> cell_size
In your case, I think only the facet_distance matters. Set it from 0.5 to 0.1.
Laurent Rineau, PhD
