- To: <>
- Subject: RE: [cgal-discuss] Volume mesh from 3D image
- Date: Tue, 16 Jul 2013 13:10:04 +0000
- Accept-language: fr-CH, de-CH, en-US
Hi Laurent, Thanks for the help, I tried to reduce the size but still there are some disturbances over the surface (shown in the figure), Is it possible to use Octree based image instead of structured one? In this way I can reduce the image pixel size and concentrate it over the skin surface.
-----Original Message-----
Le mardi 16 juillet 2013 11:09:24 Kamal Shahim a ?crit : > Hello, > I am trying to create a volumetric mesh from an inr 3D image. > > The idea is to create a volumetric mesh for patient faces. > > However, the quality of surface mesh on the skin is not as good as the > surface skin obtained by using vtkcontour filter or vtkmarchingcubes. > What is the best combination for the following parameters in order to > have a smooth surface comparable to those obtained by the contour > filters? the image pixel size is about 0.5 in each direction. > > facet_angle > facet_size > facet_distance > cell_radius_edge_ratio > cell_size
In your case, I think only the facet_distance matters. Set it from 0.5 to 0.1.
-- Laurent Rineau, PhD R&D Engineer at GeometryFactory http://www.geometryfactory.com/ Release Manager of the CGAL Project http://www.cgal.org/
-- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] Volume mesh from 3D image, Kamal Shahim, 07/16/2013
- Re: [cgal-discuss] Volume mesh from 3D image, Laurent Rineau (CGAL/GeometryFactory), 07/16/2013
- RE: [cgal-discuss] Volume mesh from 3D image, kamal.shahim, 07/16/2013
- Re: RE: [cgal-discuss] Volume mesh from 3D image, Laurent Rineau (CGAL/GeometryFactory), 07/16/2013
