cgal-discuss - Re: [cgal-discuss] Re: unexpected vertexes in constrained Delaunay triangulation.
  • To:
  • Subject: Re: [cgal-discuss] Re: unexpected vertexes in constrained Delaunay triangulation.
  • Date: Tue, 06 Aug 2013 13:53:33 +0200
Le mardi 06 août 2013 01:43:03 Bear a écrit :
> I used the typical way to construct the constrained triangulation. Please
> see the code bellow, i also attached the full code test_cgal_CT.cpp
> <http://cgal-discuss.949826.n4.nabble.com/file/n4657896/test_cgal_CT.cpp> .
Your input polygons do intersect. You can see that modifying the code that
way:
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef CGAL::Triangulation_vertex_base_2<K> VB;
> typedef CGAL::Constrained_triangulation_face_base_2<K> FB;
> typedef CGAL::Triangulation_face_base_2<K, FB> FBWI;
> typedef CGAL::Triangulation_data_structure_2<VB, FBWI> TDS;
> typedef CGAL::Exact_predicates_tag PT;
typedef CGAL::No_intersection_tag PT;
> typedef CGAL::Constrained_Delaunay_triangulation_2<K, TDS, PT> CDT;
> typedef CGAL::Constrained_triangulation_plus_2<CDT> Triangulation;
> typedef CGAL::Polygon_2<K> Ring;
> typedef Triangulation::Point Point;
The intersections explain the new points in the output.
Laurent Rineau, PhD
