cgal-discuss - Re: [cgal-discuss] unexpected vertexes in constrained Delaunay triangulation.
  • To:
  • Subject: Re: [cgal-discuss] unexpected vertexes in constrained Delaunay triangulation.
  • Date: Mon, 05 Aug 2013 17:34:14 +0200
New points will be added only if you have intersection between your constraints.
If you change the Itag of the Constrained_Delaunay_triangulation_2
class to CGAL::No_intersection_tag you will see an assertion when
an constraint intersect another one.
If you are not in this situation, please provide an minimal example showing the pb.
Sebastien.
On 08/05/2013 05:28 PM, Bear wrote:
Dear CGAL developers,
I construct a constrained Delaunay triangulation with a group of polygons,
the vertexes as input points and the edges as constraints. The polygons have
overlapped regions and edges. I find the result triangulation has vertexes
which are not from the input points. Is it a bug? How could i avoid this?
Many thanks.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/unexpected-vertexes-in-constrained-Delaunay-triangulation-tp4657889.html
