cgal-discuss - Re: [cgal-discuss] Re: unexpected vertexes in constrained Delaunay triangulation.
  • To:
  • Subject: Re: [cgal-discuss] Re: unexpected vertexes in constrained Delaunay triangulation.
  • Date: Tue, 06 Aug 2013 12:08:18 +0200
Le mardi 06 août 2013 01:43:03 Bear a écrit :
> I used the typical way to construct the constrained triangulation. Please
> see the code bellow, i also attached the full code test_cgal_CT.cpp
> <http://cgal-discuss.949826.n4.nabble.com/file/n4657896/test_cgal_CT.cpp> .
In their internal data structure, the 2D triangulations have an "infinite"
vertex, for which the coordinates are non-relevant. The operator<< of
CGAL::Triangulation_2 does output that infinite vertex to the file, with its
random coordinates. It should be the first vertex of the file. That must
explain why you see an extra vertex in your output.
Laurent Rineau, PhD
