cgal-discuss - [cgal-discuss] Problem about Euler Operators!
  • To:
  • Subject: [cgal-discuss] Problem about Euler Operators!
  • Date: Thu, 5 Sep 2013 22:19:18 -0700 (PDT)
Hello All:
Now I have solved the 3D Boolean Operation by using the Nef
polyhedron.But I find the efficiency of Nef is very low (since 5 closed
poly, in total 1000 triangles, about 3mins). So someone suggest me tha use
the Euler Operation upon the Half-edge data structure.
And i look forward the manual, but i could found a goog example
about it. So, is there anyone use the Euler Operation and HDS to solve the
3D Boolean Operation, Or somebody could give me a small but detail example ?
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-about-Euler-Operators-tp4658007.html
