- To:
- Subject: Re: [cgal-discuss] Problem about Euler Operators!
- Date: Tue, 10 Sep 2013 10:41:32 +0200
Hi,
HDS is a 2D data structure, it cannot be used for 3D objects.
You may want to have a look at the following packages
- Combinatorial Maps
- Linear Cell Complex
Best,
Monique Teillaud
http://www.inria.fr/sophia/members/Monique.Teillaud/
INRIA Sophia Antipolis - Méditerranée
Institut National de Recherche en Informatique et Automatique
Le 06/09/13 07:19, ChaoM a écrit :
Hello All:
Now I have solved the 3D Boolean Operation by using the Nef
polyhedron.But I find the efficiency of Nef is very low (since 5 closed
poly, in total 1000 triangles, about 3mins). So someone suggest me tha use
the Euler Operation upon the Half-edge data structure.
And i look forward the manual, but i could found a goog example
about it. So, is there anyone use the Euler Operation and HDS to solve the
3D Boolean Operation, Or somebody could give me a small but detail example ?
Thanks!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-about-Euler-Operators-tp4658007.html
- [cgal-discuss] Problem about Euler Operators!, ChaoM, 09/06/2013
- Re: [cgal-discuss] Problem about Euler Operators!, Monique Teillaud, 09/10/2013
- [cgal-discuss] Re: Problem about Euler Operators!, ChaoM, 09/11/2013
