- To: <>
- Subject: [cgal-discuss] FYI: Xcode build linker errors
- Date: Tue, 10 Sep 2013 14:19:20 +0100
This is odd. using CMake 2.8/XCode 4.6.3/Boost 1.5.4/QT 4.5 (the latter libraries installed via port).
I built polyhedron_3 and it came up with a longish list of link errors. It looks like the 64 bit build is also trying to link i386 components … ?
I then got CMake to output makefiles for LLVM 4.2 which did work.
Not had the time to investigate further. Is this a known issue?
- [cgal-discuss] FYI: Xcode build linker errors, g4, 09/10/2013
