cgal-discuss - Re: [cgal-discuss] Weird cmake side-effect when including CGAL
  • To:
  • Subject: Re: [cgal-discuss] Weird cmake side-effect when including CGAL
  • Date: Thu, 12 Sep 2013 13:39:59 +0200
Le jeudi 12 septembre 2013 12:58:12 David Coeurjolly a écrit :
> Well, you're right... ${CGAL_USE_FILE} appends the path to CGAL modules..
> The problem comes from me since I was using the CMAKE_MODULE_PATH as a
> variable (and not list):
> INCLUDE(${CMAKE_MODULE_PATH}/ChechSomething.cmake)
> (and surprisingly, cmake (2.8.11.2) does not report a fatal error).
> Replacing my code by simply
> INCLUDE(ChechSomething)
> Solve the issue without manually resetting the variable.
Great! Indeed, that use of INCLUDE is that the intended use of the variable
CMAKE_MODULE_PATH.
Laurent Rineau, PhD
