- Cc: cgal-discuss <>
- Subject: [cgal-discuss] Re: Weird cmake side-effect when including CGAL
- Date: Thu, 12 Sep 2013 11:13:31 +0200
Re,
I've found what was wrong and maybe something should be done in CGAL cmake
scripts: In fact, all my includes use the CMAKE_MODULE_PATH variable I've
specified for my project (and not relative explicit paths "cmake/xxx.cmake").
When doing a
INCLUDE( ${CGAL_USE_FILE} )
CGAL overwrites the CMAKE_MODULE_PATH variable which may cause problems for
further cmake scripts includes.
To fix my problem, I've just had to reset the CMAKE_MODULE_PATH after the
CGAL_USE_FILE include.
Maybe the USE_FILE could backup this variable and reset it when all CGAL
related scripts have been interpreted...
(I'm using last CGAL / cmake releases)
Le 10 sept. 2013 à 09:45, David Coeurjolly
a écrit :
> Dear All,
> I'm having a strange cmake issue when including CGAL to my project. For
> short, my main CMakeLists.txt looks like:
> INCLUDE ("cmake/CheckCGAL.cmake")
> MESSAGE(STATUS "Ok...")
> INCLUDE ("cmake/ChecKOtherPackageA.cmake")
> INCLUDE ("cmake/ChecKOtherPackageB.cmake")
> In CheckCGAL.cmake, there are the FIND_PACKAGE(CGAL) and the dedicated
> "include( ${CGAL_USE_FILE} )". Note that there is no problem here.. CGAL is
> found and all CGAL variables are fine.
> In ChecKOtherPackageXXX.cmake, I have other dependency checks and plenty
> of messages..
> The problem: when I active the CGAL dependency, cmake refuses to include
> the remaining ChecKOtherPackageXXX.cmake files. The message "Ok..." is
> displayed but cmake skips the "include" directives.
> If I turn off CGAL ( "if" on a flag in the CheckCGAL), all further
> "include"(s) are fine.
> Have you already seen such strange behavior ?
> Thanks,
> david
smime.p7s
Description: S/MIME cryptographic signature
- [cgal-discuss] Weird cmake side-effect when including CGAL, David Coeurjolly, 09/10/2013
- [cgal-discuss] Re: Weird cmake side-effect when including CGAL, David Coeurjolly, 09/12/2013
- Re: [cgal-discuss] Weird cmake side-effect when including CGAL, Laurent Rineau (CGAL/GeometryFactory), 09/12/2013
- Re: [cgal-discuss] Weird cmake side-effect when including CGAL, David Coeurjolly, 09/12/2013
