- To:
- Subject: Re: [cgal-discuss] Weird cmake side-effect when including CGAL
- Date: Thu, 12 Sep 2013 11:58:01 +0200
Le jeudi 12 septembre 2013 11:13:31 David Coeurjolly a écrit :
> Re,
> I've found what was wrong and maybe something should be done in CGAL cmake
> scripts: In fact, all my includes use the CMAKE_MODULE_PATH variable I've
> specified for my project (and not relative explicit paths
> "cmake/xxx.cmake").
> When doing a
> INCLUDE( ${CGAL_USE_FILE} )
> CGAL overwrites the CMAKE_MODULE_PATH variable which may cause problems for
> further cmake scripts includes.
> To fix my problem, I've just had to reset the CMAKE_MODULE_PATH after the
> CGAL_USE_FILE include.
> Maybe the USE_FILE could backup this variable and reset it when all CGAL
> related scripts have been interpreted...
> (I'm using last CGAL / cmake releases)
Which CGAL version do you use? That might help us understanding what happens.
The inclusion of ${CGAL_USE_FILE} should not overwrite CMAKE_MODULE_PATH but
only append something to it. Are you sure the old value of CMAKE_MODULE_PATH
is completely removed?
Laurent Rineau, PhD
- [cgal-discuss] Weird cmake side-effect when including CGAL, David Coeurjolly, 09/10/2013
- [cgal-discuss] Re: Weird cmake side-effect when including CGAL, David Coeurjolly, 09/12/2013
- Re: [cgal-discuss] Weird cmake side-effect when including CGAL, Laurent Rineau (CGAL/GeometryFactory), 09/12/2013
- Re: [cgal-discuss] Weird cmake side-effect when including CGAL, David Coeurjolly, 09/12/2013
