- To:
- Subject: Re: [cgal-discuss] CGAL on windows surface, not Pro
- Date: Tue, 08 Oct 2013 23:18:58 +0200
Hi,
On 10/07/2013 02:40 PM, Laurent Rineau (CGAL/GeometryFactory) wrote:
> and the compilation of CGAL
> application for ARM processors has never been tested by the CGAL project.
> You
> can expect troubles, because you will the a scout in that subject.
CGAL on Linux/ARM is supposed to work (there are Debian packages for it) -- at
least as long as your ARM chip has a hardware FPU with rounding mode control.
It
does not work on ARM chips with software FPU emulation (typically without
rounding mode control).
But you are probably right that nobody tested CGAL on Windows/ARM so far.
Joachim
- [cgal-discuss] CGAL on windows surface, not Pro, swazy, 10/06/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Laurent Rineau (CGAL/GeometryFactory), 10/07/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Patrick Fuerst, 10/08/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Joachim Reichel, 10/08/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Marc Glisse, 10/08/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Laurent Rineau (CGAL/GeometryFactory), 10/11/2013
- Re: [cgal-discuss] CGAL on windows surface, not Pro, Patrick Fuerst, 10/11/2013
