cgal-discuss - Re: [cgal-discuss] CGAL on windows surface, not Pro
  • To:
  • Subject: Re: [cgal-discuss] CGAL on windows surface, not Pro
  • Date: Fri, 11 Oct 2013 12:56:46 +0200
Thanks for the answers. Would love to see it work on Windows RT sometimes.
On Oct 11, 2013, at 12:06 PM, "Laurent Rineau (CGAL/GeometryFactory)" <> wrote:
Le mardi 08 octobre 2013 23:45:29 Marc Glisse a écrit :
> On Tue, 8 Oct 2013, Joachim Reichel wrote:
> > CGAL on Linux/ARM is supposed to work (there are Debian packages for it)
> > -- at least as long as your ARM chip has a hardware FPU with rounding
> > mode control. It does not work on ARM chips with software FPU emulation
> > (typically without rounding mode control).
> > But you are probably right that nobody tested CGAL on Windows/ARM so far.
> We have so far interpreted _MSC_VER as implying x86 or x86_64, to the
> point of writing asm after it, so I am quite sure it doesn't work without
> at least a few tweaks.
Marc, do you have an idea of the amount of work to support ARM chips, under Linux ou Windows RT? We can discuss that at the next CGAL developers meeting, if you plan to attend it.
Laurent Rineau, PhD
