cgal-discuss - Re: [cgal-discuss] Compilation errors in Poisson reconstruction sample code(CGAL 4.2 beta1)
  • To:
  • Subject: Re: [cgal-discuss] Compilation errors in Poisson reconstruction sample code(CGAL 4.2 beta1)
  • Date: Fri, 11 Oct 2013 08:34:23 -0700 (PDT)
Hello,
I ran into the same problem, I use Eigen 3.2 and added #define
CGAL_EIGEN3_ENABLED, but the error still occures. Does that mean that I did
not install it correctly?
I downloaded the zip for Eigen 3.2.0 here:
http://eigen.tuxfamily.org/index.php?title=Main_Page
Then I extracted it and copied the signature_of_eigen3_matrix_library as
well as the header folder called "Eigen" to my minGW/include folder.
When I configured CGAL with Eigen support in cmake, it found Eigen and did
not throw errors, also generating the makefile as well as running make and
make install on CGAL worked. So I assumed, everything was alright. But maybe
I missed a step?
Can you please explain, how you added Eigen support to your CGAL
installation?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compilation-errors-in-Poisson-reconstruction-sample-code-CGAL-4-2-beta1-tp4656940p4658181.html
