- To:
- Subject: [cgal-discuss] Meshing of polyhedron persistently fails
- Date: Thu, 17 Oct 2013 17:57:50 +0100
I'm trying to create a volume mesh of a polyhedron with many faces, but I keep getting the error:
construct initial points:
8/8 initial point(s) found...
Start surface scan...end scan. [Bad facets:12]
Refining Surface...
Legende of the following line: (#vertices,#steps,#facets to refine,#tets to refine)
(3286,3277,0,0) (2847.9 vertices/s))))
Total refining surface time: 1.15069s
Start volume scan...end scan. [Bad tets:9713]
Refining...
(7617,4330,0,37339) (11173.1 vertices/s)terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
Expr: !r_tr_.is_infinite(*cell_it)
File: /usr/include/CGAL/Mesh_3/Refine_cells_3.h
Line: 385
What I'm doing is surface meshing a sphere, converting the surface mesh to a polyhedron, and trying to generate a volume mesh of the polyhedron (the motivation is to add/subtract polyhedra to create more complicated domains). The code that reproduces the error (using CGAL 4.2 and GCC 4.8) is attached. The code is basically a concatenation of the demos in sections 48.3.1 and 51.3.2. Any suggestions to get this working?
Garth
#include <CGAL/Surface_mesh_default_triangulation_3.h> #include <CGAL/Complex_2_in_triangulation_3.h> #include <CGAL/make_surface_mesh.h> #include <CGAL/Implicit_surface_3.h> #include <CGAL/IO/output_surface_facets_to_polyhedron.h> #include <CGAL/Polyhedron_3.h> #include <CGAL/Mesh_triangulation_3.h> #include <CGAL/Mesh_complex_3_in_triangulation_3.h> #include <CGAL/Mesh_criteria_3.h> #include <CGAL/Polyhedral_mesh_domain_3.h> #include <CGAL/make_mesh_3.h> #include <CGAL/refine_mesh_3.h> typedef CGAL::Surface_mesh_default_triangulation_3 Tr; typedef CGAL::Complex_2_in_triangulation_3<Tr> C2t3; typedef Tr::Geom_traits GT; typedef GT::Sphere_3 Sphere_3; typedef GT::Point_3 Point_3; typedef GT::FT FT; typedef GT::Kernel K; typedef FT (*Function)(Point_3); typedef CGAL::Implicit_surface_3<GT, Function> Surface_3; FT sphere_function (Point_3 p) { const FT x2=p.x()*p.x(), y2=p.y()*p.y(), z2=p.z()*p.z(); return x2+y2+z2-1; } typedef CGAL::Polyhedron_3<K> Polyhedron; // 3D mesh typedefs typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain; typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr3; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr3> C3t3; typedef CGAL::Mesh_criteria_3<Tr3> Mesh_criteria; using namespace CGAL::parameters; int main() { Tr tr; C2t3 c2t3 (tr); // defining the surface Surface_3 surface(sphere_function, // pointer to function Sphere_3(CGAL::ORIGIN, 2.)); // bounding sphere // defining meshing criteria CGAL::Surface_mesh_default_criteria_3<Tr> criteria(30., // angular bound 0.1, // radius bound 0.1); // distance bound // Mesh surface CGAL::make_surface_mesh(c2t3, surface, criteria, CGAL::Non_manifold_tag()); // Copy surface mesh to polyhedron Polyhedron polyhedron; CGAL::output_surface_facets_to_polyhedron(c2t3, polyhedron); // --- Mesh 'polyhedralised' sphere // Create domain Mesh_domain domain(polyhedron); Mesh_criteria criteria3(facet_angle=30, facet_size=0.05, facet_distance=0.15, cell_radius_edge_ratio=2, cell_size=0.05); // Mesh generation std::cout << "Build 3D mesh" << std::endl; C3t3 c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria3, no_perturb(), no_exude()); }
- [cgal-discuss] Meshing of polyhedron persistently fails, Garth N. Wells, 10/17/2013
- Re: [cgal-discuss] Meshing of polyhedron persistently fails, Phil Weir, 10/30/2013
- Re: [cgal-discuss] Meshing of polyhedron persistently fails, Phil Weir, 10/31/2013
- Re: [cgal-discuss] Meshing of polyhedron persistently fails, Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
