cgal-discuss - Re: [cgal-discuss] Meshing of polyhedron persistently fails
  • To:
  • Subject: Re: [cgal-discuss] Meshing of polyhedron persistently fails
  • Date: Wed, 30 Oct 2013 18:34:27 +0100
Le jeudi 17 octobre 2013 17:57:50 Garth N. Wells a écrit :
> I'm trying to create a volume mesh of a polyhedron with many faces, but
> I keep getting the error:
> construct initial points:
> 8/8 initial point(s) found...
> Start surface scan...end scan. [Bad facets:12]
> Refining Surface...
> Legende of the following line: (#vertices,#steps,#facets to refine,#tets
> to refine)
> (3286,3277,0,0) (2847.9 vertices/s))))
> Total refining surface time: 1.15069s
> Start volume scan...end scan. [Bad tets:9713]
> Refining...
> to refine)
> (7617,4330,0,37339) (11173.1 vertices/s)terminate called after throwing
> an instance of 'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Expr: !r_tr_.is_infinite(*cell_it)
> File: /usr/include/CGAL/Mesh_3/Refine_cells_3.h
> Line: 385
> What I'm doing is surface meshing a sphere, converting the surface mesh
> to a polyhedron, and trying to generate a volume mesh of the polyhedron
> (the motivation is to add/subtract polyhedra to create more complicated
> domains). The code that reproduces the error (using CGAL 4.2 and GCC
> 4.8) is attached. The code is basically a concatenation of the demos in
> sections 48.3.1 and 51.3.2. Any suggestions to get this working?
The polyhedron generated by the intermediate step is probably not properly
closed. Can you check?
Laurent Rineau, PhD
