- To: ,
- Subject: [cgal-discuss] CGAL 4.3 Released, Computational Geometry Algorithms Library
- Date: Thu, 17 Oct 2013 19:25:23 +0200
The CGAL Open Source Project is pleased to announce the release 4.3
of CGAL, the Computational Geometry Algorithms Library.
Besides fixes to existing packages, the following has changed since
CGALÂ 4.2:
o The CGAL Manual generated with Doxygen
The documentation of CGAL is now generated with Doxygen:
http://doc.cgal.org/4.3/
The conversion to Doxygen from our home-made tools was not completely
smooth. Please report any documentation bug you may discover to the
Inria Forge bug tracker:
https://gforge.inria.fr/tracker/?atid=13845&group_id=52&func=browse
o 2D Periodic Triangulations (new package)
This package allows to build and handle triangulations of point sets in
the two dimensional flat torus. Triangulations are built incrementally
and can be modified by insertion or removal of vertices. They offer
point location facilities. The package provides Delaunay triangulations
and offers nearest neighbor queries and primitives to build the dual
Voronoi diagrams.
See http://www.cgal.org/releases.html for a complete list of changes.
The CGAL project is a collaborative effort to develop a robust,
easy-to-use, and efficient C++ software library of geometric data
structures and algorithms, like
- triangulations (2D constrained triangulations, Delaunay triangulations
and periodic triangulations in 2D and 3D),
- Voronoi diagrams (for 2D and 3D points, 2D additively weighted
Voronoi diagrams, and segment Voronoi diagrams),
- Boolean operations on polygons and polyhedra,
- regularized Boolean operations on polygons with curved arcs
- arrangements of curves,
- mesh generation (2D, 3D and surface mesh generation,
surface mesh subdivision and parametrization),
- alpha shapes (in 2D and 3D),
- convex hull algorithms (in 2D, 3D and dD),
- operations on polygons (straight skeleton and offset polygon),
- search structures (kd trees for nearest neighbor search, and
range and segment trees),
- interpolation (natural neighbor interpolation and placement of
streamlines),
- optimization algorithms (smallest enclosing sphere of points or
spheres, smallest enclosing ellipsoid of points, principal
component analysis),
- kinetic data structures
Some modules are distributed under the terms of the LGPL Open Source
license (GNU Lesser General Public License v3 or later versions).
Most modules are distributed under the terms of the GPL Open Source
license (GNU General Public License v3 or later versions).
If your intended usage does not meet the criteria of the
aforementioned licenses, a commercial license can be purchased from
GeometryFactory (http://www.geometryfactory.com/).
For further information and for downloading the library and its
documentation, please visit the CGAL web site: http://www.cgal.org/
Laurent Rineau, PhD
- [cgal-discuss] CGAL 4.3 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 10/17/2013
- Re: [cgal-discuss] CGAL 4.3 Released, Computational Geometry Algorithms Library, Joachim Reichel, 10/21/2013
