cgal-discuss - Re: [cgal-discuss] Is there any good method to get the index of one triangle in triangles?
  • To:
  • Subject: Re: [cgal-discuss] Is there any good method to get the index of one triangle in triangles?
  • Date: Sun, 27 Oct 2013 20:47:50 -0700 (PDT)
Thank you for your answer, and I will try the method.
Sebastien Loriot (GeometryFactory) wrote
> In 3D 4 points = 4 finite triangles.
> Are you in 2D or in 3D?
> In 2D have a look at this example:
> http://doc.cgal.org/latest/Triangulation_2/index.html#Triangulation_2AddingColors
> replace color with a std::size_t
> In 3D, you can do the same but need to store the info in the 3D cells
> and duplicate it since a triangle is incident to two 3D cells,
> You can use a std::array&lt;std::size_t,4&gt; and use the index of the
> vertex
> opposite to the triangle to refer to it.
> Sebastien.
> On 10/25/2013 09:08 AM, ffmm3 wrote:
>> Hi,
>> I have generage triangles using Delaunay triangulaition using several
>> points, and now I have the vertices coorinates of one triangle, and I
>> want
>> find the index of the triangle in triangles.
>> Example:
>> For simplicity, using only four points:
>> and generate two triangles using the Delaunat_trianglation_3 class:
>> the first triangle:
>> the second triangle:
>> now I have the three points(p0, p1, p3), and want to find the index of
>> this
>> triangle in the triangles. Is there any efficient method to do so? As you
>> know, allways there are much more than only four points, so the
>> efficiency
>> is very important.
>> View this message in context:
>> http://cgal-discuss.949826.n4.nabble.com/Is-there-any-good-method-to-get-the-index-of-one-triangle-in-triangles-tp4658289.html
>> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
http://cgal-discuss.949826.n4.nabble.com/Is-there-any-good-method-to-get-the-index-of-one-triangle-in-triangles-tp4658289p4658309.html
