Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
- To:
- Subject: Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization"
- Date: Mon, 28 Oct 2013 09:33:10 +0200
Hi,
I really need an answer urgently, please.
Burak
Cts, 2013-10-26 tarihinde 23:18 +0300 saatinde, Burak ER yazdı:
> Hi,
> Would you please guide me to achieve a meshing procedure where I only
> set the minimum element volume. Therefore, I have the ability to change
> the mesh density with having it uniform with using a single parameter.
> Is it possible? Can you provide me a simple example of code?
> Thank you in advance.
> Burak
> Cum, 2013-10-25 tarihinde 16:48 +0200 saatinde, Sebastien Loriot
> (GeometryFactory) yazdı:
> > On 10/25/2013 04:44 PM, Burak ER wrote:
> > > Hi Sebastien,
> > > I am now having difficulties with the space filling tetrahedrons. They
> > > are too small[1] when compared to other tetrahedrons. How can I prevent
> > > this behavior?
> > > Sorry for these newbie questions.
> > I guess it's coming from the way you protected the sharp edges. You need
> > to reduce the number of protecting balls on the sharp edges.
> > Sebastien.
> > > Thank you.
> > > Burak
> > > [1]http://s10.postimg.org/rblr196hl/Screenshot_from_2013_10_25_17_40_10.png
> > > Cum, 2013-10-25 tarihinde 16:13 +0300 saatinde, Burak ER yazdı:
> > >> Thank you,
> > >> This solved my problem.
> > >> Burak ER
> > >> Cum, 2013-10-25 tarihinde 12:03 +0200 saatinde, Sebastien Loriot
> > >>> You need to protect the edges of your box.
> > >>> One solution is to do like this example:
> > >>> http://doc.cgal.org/latest/Mesh_3/index.html#Mesh_3MeshingDomainswithSharpFeatures
> > >>> or to protect them by hand.
> > >>> Sebastien.
> > >>> On 10/25/2013 11:20 AM, Burak ER wrote:
> > >>>> Sorry for the not working link. You can find it here.
> > >>>> <http://s16.postimg.org/pv4ehn3et/Screenshot_from_2013_10_25_12_17_21.png>
> > >>>> Cum, 2013-10-25 tarihinde 12:14 +0300 saatinde, Burak ER yazdı:
> > >>>>> Dear Sebastian,
> > >>>>> This may not be a minimal example. I have created a python interface
> > >>>>> for my application. Within this interface I divide the off file into
> > >>>>> tetrahedrons with CGAL c++ api on the background. I use this
> > >>>>> generation code on the c++ side;
> > >>>>> #include <CGAL/Exact_predicates_inexact_constructions_kernel.h>
> > >>>>> #include <CGAL/Mesh_triangulation_3.h>
> > >>>>> #include <CGAL/Mesh_complex_3_in_triangulation_3.h>
> > >>>>> #include <CGAL/Mesh_criteria_3.h>
> > >>>>> #include <CGAL/Polyhedral_mesh_domain_3.h>
> > >>>>> #include <CGAL/make_mesh_3.h>
> > >>>>> #include <CGAL/refine_mesh_3.h>
> > >>>>> #include <iostream>
> > >>>>> // IO
> > >>>>> #include <CGAL/IO/Polyhedron_iostream.h>
> > >>>>> // Domain
> > >>>>> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> > >>>>> typedef CGAL::Polyhedron_3<K> Polyhedron;
> > >>>>> typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain;
> > >>>>> // Triangulation
> > >>>>> typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
> > >>>>> typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr> C3t3;
> > >>>>> // Criteria
> > >>>>> typedef CGAL::Mesh_criteria_3<Tr> Mesh_criteria;
> > >>>>> // To avoid verbose function and named parameters call
> > >>>>> using namespace CGAL::parameters;
> > >>>>> class MeshElement;
> > >>>>> void Mesh(void)
> > >>>>> boost::filesystem::path mypath(filename);
> > >>>>> std::ifstream input(filename.data());
> > >>>>> if(mypath.extension()!=boost::filesystem::path(".off")){
> > >>>>> std::string errormessage ="Invalid extension is specified with
> > >>>>> the
> > >>>>> mesh file";
> > >>>>> throw std::invalid_argument(errormessage);
> > >>>>> // Create input polyhedron
> > >>>>> Polyhedron polyhedron;
> > >>>>> input >> polyhedron;
> > >>>>> // Create domain
> > >>>>> Mesh_domain domain(polyhedron);
> > >>>>> // Mesh criteria (no cell_size set)
> > >>>>> Mesh_criteria criteria(facet_angle, facet_size,
> > >>>>> facet_distance,/*facet_topology*/
> > >>>>> cell_radius_edge_ratio, cell_size);
> > >>>>> // Mesh generation
> > >>>>> c3t3.clear();
> > >>>>> c3t3 = CGAL::make_mesh_3<C3t3>(domain, criteria, no_perturb(),
> > >>>>> no_exude());
> > >>>>> elems.clear();// clear our vector
> > >>>>> interfacingpairs.clear();
> > >>>>> handlemap.clear();
> > >>>>> elems.resize(c3t3.number_of_cells_in_complex()); // resize it as
> > >>>>> the
> > >>>>> new number of elements
> > >>>>> size_t i=0;
> > >>>>> * This is not a nice way to index elements
> > >>>>> * we could use cell_with_info structure of cgal but really how
> > >>>>> to
> > >>>>> use that? No tutorial, no example at all on its document!!!
> > >>>>> for(C3t3::Cells_in_complex_iterator
> > >>>>> it=c3t3.cells_begin();it!=c3t3.cells_end();it++){
> > >>>>> //Create new elements
> > >>>>> //share_ptr handles deletion of the newly created element
> > >>>>> elems[i]=shared_ptr<MeshElement>(new Linear4NodeTetMeshElem(it));
> > >>>>> //Give an index to handle
> > >>>>> handlemap[it]=i;
> > >>>>> i++;
> > >>>>> // Add interactions
> > >>>>> //For each neighbor of the currrent iterator
> > >>>>> for(int j=0;j<4;j++)
> > >>>>> C3t3::Cell_handle neigh=it->neighbor(j);
> > >>>>> /*Check if we have this neighbor handle*/
> > >>>>> if(c3t3.is_in_complex(neigh))
> > >>>>> size_t indexel=handlemap[it];
> > >>>>> size_t indexneigh=handlemap[neigh];
> > >>>>> //Get element and its neighbors from element list
> > >>>>> shared_ptr<MeshElement> el;
> > >>>>> shared_ptr<MeshElement> neighel;
> > >>>>> //Change the ordering of the elements
> > >>>>> if(indexel<indexneigh){
> > >>>>> el=elems[indexel];
> > >>>>> neighel=elems[indexneigh];}
> > >>>>> else{
> > >>>>> neighel=elems[indexel];
> > >>>>> nodePairsIndices indiceofpairs;
> > >>>>> //Get shared node list
> > >>>>> indiceofpairs=getNodeCon(el,neighel);
> > >>>>> //check if there is a face share
> > >>>>> if(indiceofpairs.size()>=3)
> > >>>>> //Create the pair
> > >>>>> ElementPair pair(el,neighel,indiceofpairs);
> > >>>>> //Add it into the interfacing pair list
> > >>>>> if(!interfacingpairs[pair])
> > >>>>> interfacingpairs[pair]=shared_ptr<ElementPair>(new
> > >>>>> ElementPair(el,neighel,indiceofpairs));
> > >>>>> std::cout<<"Meshing is complete "<<std::endl;
> > >>>>> std::cout<<"Number of tetrahedral elements
> > >>>>> "<<elems.size()<<std::endl;
> > >>>>> std::cout<<"Number of interaction elements
> > >>>>> "<<interfacingpairs.size()<<std::endl;
> > >>>>> Using this function and the off file in the attachment;
> > >>>>> When I use the parameters as
> > >>>>> facet_angle=33,
> > >>>>> facet_distance=.6,
> > >>>>> facet_size=0.6,
> > >>>>> cell_radius_edge_ratio=0.11,
> > >>>>> cell_size=1e-3
> > >>>>> The result is 5580 elements and they are distributed as here
> > >>>>> <http://>
> > >>>>> where you can see the empty parts on the boundary of the plate.
> > >>>>> Also slight change on the cell_radius_edge_ratio=0.15 makes it even
> > >>>>> worser as here.
> > >>>>> <http://s14.postimg.org/o8j6yl07l/Screenshot_from_2013_10_25_12_08_06.png>
> > >>>>> What do you think the problem is?
> > >>>>> Burak
> > >>>>> Cum, 2013-10-25 tarihinde 09:28 +0200 saatinde, Sebastien Loriot
> > >>>>>> It might help if you share a minimal example showing the pb.
> > >>>>>> Sebastien.
> > >>>>>> On 10/25/2013 09:26 AM, Burak ER wrote:
> > >>>>>>> Dear Cgal Users,
> > >>>>>>> I really need help on this problem. Still waiting for an answer.
> > >>>>>>> Burak ER
> > >>>>>>> Pzt, 2013-10-21 tarihinde 18:40 +0300 saatinde, Burak ER yazdı:
> > >>>>>>>> Dear Cgal Users,
> > >>>>>>>> I am trying to mesh a rectengular prism domain from an off file
> > >>>>>>>> into
> > >>>>>>>> tetrahedral elements using cgal. But whatever parameters I use
> > >>>>>>>> within
> > >>>>>>>> criteria structure, I get a mesh where the boundaries are not
> > >>>>>>>> conserved
> > >>>>>>>> rather they are "uneven".
> > >>>>>>>> What may cause that? How to force keeping boundaries exact while
> > >>>>>>>> meshing?
> > >>>>>>>> Burak ER
> > >>>>>>>> Research Assistant
> > >>>>>>>> Mechanical Engineering Department
> > >>>>>>>> Bursa Technical University
> > >>>> Burak ER
> > >>>> <mailto:>>
> > >>>> Bu elektronik posta ve ekleri sadece adreste belirtilen kisi veya
> > >>>> kurulusun kullanimi icin gonderilmektedir. Bu mesaj tarafiniza
> > >>>> yanlislikla ulasirsa, lutfen gonderen kisiyi bilgilendiriniz ve
> > >>>> mesaji
> > >>>> sisteminizden siliniz. Mesajda ve eklerinde yer alan bilgilerin her
> > >>>> ne
> > >>>> sekilde olursa olsun ucuncu kisiler ile paylasilmasi hukuki ve cezai
> > >>>> sorumluluk dogurabilir. Bursa Teknik Universitesi'nin, bu mesaj ve
> > >>>> eklerinin icerigi ve yayimi ile ilgili hicbir sorumlulugu
> > >>>> bulunmamaktadir.
> > >>>> This email and the attachments are sent to the individual or entity
> > >>>> defined in the address field only. If you are not the intended
> > >>>> recipient or have received the message in error, please notify the
> > >>>> sender and remove the message from your system immediately. Sharing
> > >>>> the
> > >>>> information in the message or the attachments with the 3rd parties
> > >>>> may
> > >>>> cause legal rules and penalties to apply. Bursa Technical University
> > >>>> has
> > >>>> no responsibility on the submission of this message and the
> > >>>> attachments.
> > >> Burak ER
> Burak ER
Burak ER
- [cgal-discuss] "About conserving the boundary polyhedron", Burak ER, 10/21/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Burak ER, 10/25/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Sebastien Loriot (GeometryFactory), 10/25/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Burak ER, 10/26/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Burak ER, 10/28/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Sebastien Loriot (GeometryFactory), 10/28/2013
- Re: [cgal-discuss] "About conserving the boundary polyhedron while tetrahedral discretization", Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
