- To:
- Subject: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?
- Date: Fri, 25 Oct 2013 08:13:50 -0700 (PDT)
Hello,
I am fairly new to c++ and very new to CGAL. I got the example 3D Mesh
Generation code for the implicit sphere to compile, and am playing around
with parameters. My problem seems so simple but I just can't figure it out.
I am very confused on how to actually change the radius of the generated
sphere.
The example code says
// Domain (Warning: Sphere_3 constructor uses squared radius !)
Mesh_domain domain(sphere_function, K::Sphere_3(CGAL::ORIGIN, 2.));
I saw the warning and assumed that 2. was the squared radius value. However,
no matter what number is put in here, the resulting sphere will always have
a radius of 1. I was able to force it by modifying the sphere_function,
given as:
// Function
FT sphere_function (const Point& p)
{ return CGAL::squared_distance(p, Point(CGAL::ORIGIN))-1; }
For example, if I compile the code with
{ return CGAL::squared_distance(p, Point(CGAL::ORIGIN))-100; }
Mesh_domain domain(sphere_function, K::Sphere_3(CGAL::ORIGIN, 100.));
I will get a sphere with radius 10, as desired. But I suspect I am not
supposed to modify the sphere_function in this way? One problem is I don't
know how to use a variable for the radius in the sphere_function.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-Mesh-Generation-Sphere-example-changing-radius-tp4658300.html
- [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, msmith81, 10/25/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Sebastien Loriot (GeometryFactory), 10/26/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, msmith81, 10/28/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Sebastien Loriot (GeometryFactory), 10/28/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
