- To:
- Subject: Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?
- Date: Mon, 28 Oct 2013 16:09:38 +0100
If you want to hold a state you need to use a functor instead of a function.
Sebastien.
On 10/28/2013 02:43 PM, msmith81 wrote:
thanks for confirming that I do need to modify the sphere_function, but I
tried adding a variable to the sphere_function parameters, as:
FT sphere_function (const Point& p, K::FT squared_radius)
{ return CGAL::squared_distance(p, Point(CGAL::ORIGIN))-squared_radius; }
and it no longer compiled because the Mesh_domain constructor didn't like
the sphere_function any more... I'm confused how to change the radius with a
variable since I'm not actually calling the sphere function myself. How do I
pass a variable to the sphere function to be the radius?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/3D-Mesh-Generation-Sphere-example-changing-radius-tp4658300p4658319.html
- [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, msmith81, 10/25/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Sebastien Loriot (GeometryFactory), 10/26/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, msmith81, 10/28/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Sebastien Loriot (GeometryFactory), 10/28/2013
- Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
