cgal-discuss - Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?
  • To:
  • Subject: Re: [cgal-discuss] 3D Mesh Generation Sphere example - changing radius?
  • Date: Tue, 29 Oct 2013 11:23:51 +0100
Le lundi 28 octobre 2013 13:57:10 msmith81 a écrit :
> thanks! It appears that functors are just what I was looking for... but I am
> too much of a newb to get them to work I've never used functors before -
> can someone with more c++ experience tell me what I am missing? I found
> this source
> <http://www.stanford.edu/class/cs106l/course-reader/Ch13_Functors.pdf> and
> wrote a functor as:
> class SphereFunction {
> public:
> explicit SphereFunction(const FT sr) : squaredRadius(sr) {}
> FT operator() (const Point& p)
> { return CGAL::squared_distance(p, Point(CGAL::ORIGIN))-squaredRadius; }
> private:
> const FT squaredRadius;
Your operator() should be const:
FT operator() (const Point& p) const
> I then tried calling this in the code as:
> FT radius = 10.0;
> SphereFunction sphere_function(radius*radius);
> Mesh_domain domain(sphere_function, K::Sphere_3(CGAL::ORIGIN,
> (radius*radius*2.0)));
> but it doesn't compile because "cannot convert parameter 1 from
> 'SphereFunction' to 'Function (__cdecl &)' "
> I suspect that the problem has a lot to do with these two typedef lines:
> typedef FT (Function)(const Point&);
> typedef CGAL::Implicit_mesh_domain_3<Function,K> Mesh_domain;
> but with my limited c++ knowledge, I just have no idea what to modify or how
> to modify it. Can someone please help?
'Function' is the type of the function 'sphere_function'.
Replace those two lines with:
typedef CGAL::Implicit_mesh_domain_3<SphereFunction,K> Mesh_domain;
and be sure that the declaration of SphereFunction appears before that line. Or add a forward declaration of your class:
class SphereFunction;
Laurent Rineau, PhD
